Originally Posted by
AJW
I'll be installing my design on the weekend - see how it goes.
I've got a temporary design on protoboard, then I'll make a PCB if it works ok.
Don - good find with that programmable module, probably would have used that if I was starting from scratch.
Do you have to tie the trigger to GND or is it OK floating?
See how my version goes if it doesn't work I might have a look at this module.
Would be nice to have the relay and module all mounted on one PCB.
Where I'm looking to mount the PCB behind the gear lever there's about 12 min thickness.
AJW: I've asked this same question of the manufacture and I've yet to get a response, but I beleive that it can just be left unconnected. But you could always connect the trigger to earth if you want - it wont do any harm.
The thickness of the completed version II switch (as in my pics) is 12.5 mm (as measured with a vernier calliper) without the heat-shrink tubing, so it should fit snugly in the space behind the gear lever.
As for putting both the module and the relay/diode on the same board, this is a personal choice as well. I've kind-of done this in my approach, but I've then mounted the "vero" board to the back of the module to reduce the size of the unit (at the expense of the thickness). Choosing a bigger board makes the unit thinner at the expense of width and length! Personal preference (as I said)
Matt now has the fully constructed prototype version1 unit, so I'm hoping to get feedback shortly.
EDIT: I have now received a reply from the memory module manufacturer (thanks Slava) - his advice is that the Trigger wire should be left not connected
