Page 18 of 20 FirstFirst ... 81617181920 LastLast
Results 171 to 180 of 191
Thread: Golf mk7: Auto Start/Stop disable switch - who wants to help?
  1. #171
    From a few of the other posts, it seems as though the 2v from the button is sufficient to switch an opto coupler fine.
    I guess my question in the latest post is, using the schematic from the italian website, posted a few pages back, with transistors, is that the button never really is true ground, It always has a small voltage potential of 5mv or 67mv. Is that LOW enough for the cars computer to recognise it as being pressed.
    I was initially wondering would it be worthwhile using the transistors or would it be a better idea to use the optocouplers and isolate both circuits from each other but now im leaning towards the opto couplers as they are 'safe', my electrical knowledge is limited in this regard.
  2. #172
    My other question was actually what is the safest way to test this, as i didn't have the wiring diagram. But after more probing with multimeters i was able to conclude that it was infact a regular switch, pulled to ground when not pressed and pulled high to 12v when pressed. I was then comfortable to probe it with a 12v wire to test the switch action and it worked fine.
    Are you able to share your source for the wiring schematics at all? Wondering where i would be able to find them.
  3. #173
    wookie: I'm repeating myself from our previous discussion on post #141.
    Here's the spec for the electrical characteristics of the LED in the opto-coupler from an earlier design (it's from the 4N28 datasheet):
    The vertical scale in the picture is the voltage across the LED in the opto-coupler. As you can see, 2 Volts is sufficient, but this is not the voltage at the button because you will need to include some form of current-limiting ballast into the LED circuit (LEDs are current devices, they are NOT voltage devices). Likely you will use a series resistor for this purpose -so you will lose some of the 2 Volts from the button across the resistor. The amount of voltage loss across the resistor is dependent on the operating current that you choose for the LED
    I'm a bit lost about your question regarding the collector-emitter turn-on voltage if a transistor is used. From my wiring diagram it is clear that the ESP button applies a 12V pulse to pin #39 on the ABS module (@address hex03). When the button is open, I suspect the pin voltage floats (I assume that the pin is connected to an open-collector circuit inside the module - this is a complete guess). So- your application is very different to my original design since the ESP button doesn't earth the ABS pin. But if you want to persist with this application, simply look for a transistor with a low saturation voltage, or try using a Field-Effect-Transistor
    As for your repeated questions regarding access to wiring schemes, I'm not aware of any such schemes that will give you the internal circuits for the control modules - which is what you will want to understand the characteristics of pin #39. These circuit wiring diagrams are propriety information that are owned by VW and it's entirely unlikely that any part of these details will be available in the public domain. That's why I took a very conservative design approach in my device - because I had no understanding of the internal module circuits.
  4. #174
    Hey Don,
    Sorry to sound like a bother. But I think we are talking about two different things.
    I was saying that the BJT transistor circuits provided on the italian website doesn't give truly 0v when triggering the button, but actually 5mv-65mv. I would assume this is LOW enough for the cars control unit to think the button has been pressed. Im not asking anything about the 2v when NOT Pressed anymore.
    I was also asking where YOU get your circuit diagrams. especially the ones showing the internal workings of the SS button and the internal workings of the Traction control button. I understand they are owned by VW, but you are getting them from somewhere to show them in your circuit diagrams are you not?
    You have diagrams showing the SS switch is just pulled to ground and the TCS switch is pulled HIGH to 12V when activated, or did you just make these images yourself.
    I thank you for your help. although at this stage, i believe you think i'm being a nuisance, when that is not my intention.
  5. #175
    Just to be clear, im specifically wondering where your source is for these wiring diagrams. I understand everything outside the RED box is probably designed by yourself. is everything in the red box designed by yourself also, or is that a screenshot from a VW wiring schematic.Golf mk7: Auto Start/Stop disable switch - who wants to help?-untitled-jpg
  6. #176
    Oct 2018
    Qld Australia
    Really keen to do this in my 103tsi wagon. It’s one of the few things I dislike about the car.
    I’m having trouble finding parts on eBay.
    Ive used keywords: mono, monostable, mono timer etc
    Can anyone steer me in the right direction?
    Maybe I’m better off going to a Jaycar or somewhere similiar?
    Thanks in advance
  7. #177
    Jan 2015
    United States
  8. #178
    Jan 2015
    United States
    I got it done today on my 2019 VW Tiguan
    Disclaimer: Any person, who decides to perform this modification, does so at their own risk.
    I shall not be liable for any kind of damage, whether direct or indirect, resulting from use of
    the information provided in this post.... Just don't do it!
    There are many threads about how to disable the engine auto stop / start feature on new vehicles, this mod
    is just one more way to do it, but more vehicle specific. I will leave at the end of this post links to other treads
    that I found about this topic.
    Parts:
    1. DROK 12 Volt Timer Relay: Amazon Link
    2. DROK 12 Volt Timer Relay: Instruction Manual
    3. Adecco Cloth Tape: Amazon Link
    4. Electric tape + soldering kit
    5. 24 Gauge Wires: Amazon Link
    To supply power to the Timer Relay I splice the cables going to the Cigarette Lighter ( Same connection I used for my radar detector)
    the brown wire is the negative, Green with Red is the positive. Always check voltage with Multiplier.
    DROK 12 Volt Timer Relay Connection Diagram
    More information about how to dissemble center console and access this wires on other vehicles can be found HERE.
    There are many different way to connect this wires, I like to strip about 2 mm of the insulation on the wire with a knife,
    solder the wires and cover with electrical tape. Then I wrap all the wiring with Cloth Tape.
    I secured the Timer Relay module with Velcro.
    Programming the Time Delay Module:
    1. Product Function: P-2
    2. T-1 ( Timer 1 = time module will wait to turn the relay on) at 30 sec.
    3. T-2 ( Timer 2 = time relay will remain active) at 0.1 sec.
    4. Mode C: Timer starts when module is power on, after 30 sec. relay activates for 0.1 sec.
    Other Links:
    SSAM Module Installation Instructions
    SSAM Module Page link
    Automatic Start Stop kill switch - The answer!! (Link 1)
    Disable Start/Stop on Golf mkVII - VCDS tweak
  9. #179
    Jan 2019
    Amsterdam
    I've been reading this thread very carefully and made the assumption that this should work for a Passat MY2015 also.
    So I started ordering parts and build the Auto S/S Kill switch: Closed Loop Design.
    [IMG]<a href="https://ibb.co/vHCKmL6"><img src="https://i.ibb.co/80nS2PL/workbench.jpg" alt="workbench" border="0"></a>[/IMG]
    I was very happy with the result and started testing it on my bench. Everything worked okay, so next step was to put in the car. There thing went bad..... the closed loop wasn't working. So I measured the voltage on the black/grey wire. It was only 1,1Volts.
    I think I've read in this thread that a Golf Mk7 has a voltage of 2Volts. This mean I need to redesign the circuit to make it work
  10. #180
    Jun 2018
    Redmond, WA
    I've been following this thread for a while. This timer circuit seemed perfect, but it switches the power line, not ground. However the guy who sells the timers, also makes a version that switches ground (sink). I used this version, and it couldn't have gone better.
    I used these connectors to make a plug-in harness:
    2/4/10sets/lot 10 Pin/Way Male Feamle Lift Switch Seat Adjustment Plug Connector For Volkswagen AUDI 6R0 972 930 1K0 971 992-in Cables, Adapters & Sockets from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
    It's a simple design, all the wires are duplicated as a passthrough, but I also linked in the timer to the power, ground, and switch signal lines.
    I even was able to program it outside the car with a test power supply I have. I plugged it in, and it worked like a champ first time out. It only works on initial startup, but that's exactly what I wanted, so I can still enable it on the fly if I want to. That was all I needed, no other component. It's so nice having this ability now!
    As an alternative to the Auto S/S kill switch that is described on post #1 of this thread, the following design uses a different "programmable" module that is readily available from the net. The "Multi-Functional Delay Timer" (MFDT) can be programmed to undertake 17 x different timing functions, but as used in this design, the inbuilt function #7 performs the exact timing characteristics that are described in post #1 of this thread.
    The MFTD can be purchased from EBay and Amazon (see link below), or it can be obtained directly from the distributor via the last link below:
    Multi-functional Delay Timer
    The MFDT has 6 x wires as shown in the diagram below:
    As indicated, the device has the same four wires as per the original Mono (i.e. Vcc, Earth, Vout and Trigger) plus it has two additional wires that are used for programming the T1 and T2 timing periods.
    The circuit diagram for the MFTD unit is shown in the diagram below:
    As indicated, the connections are the same as those for the Mono except that the Trigger wire is not used and the two programming wires are not connected (these wires will be used later). Also, the "freewheeling" diode across the relay coil is not required because a diode has already been included for this purpose inside the MFDT.
    Construction
    1. Solder the relay (all legs) and the diode onto a small piece of "Vero" board so that the components are mounted on the track side (the relay should be oriented so that "notch" in on the LHS of the board as shown in the Back-view picture below). Before mounting the relay, remember to remove a section of the track where the relay package is to be placed so that the pins on opposite sides of the relay don't short each-other.
    2. Place a piece of double sided tape to one of the faces on the MFDT and secure the vero board to the other side of the tape
    3. Solder the Red, Black and Yellow wires on the MFDT to the components on the vero board as per the circuit diagram
    4. Solder three wires to the vero board for the connections to be made to the centre console switch as per the circuit diagram.
    5. The three wires coloured White, Green and Blue should not be connected
    The pictures below indicate the finished Auto S/S kill switch: Alternate design
    Programming Circuit
    Using a test bench power supply, or a 12 Volt batttery construct the ciruit diagram below to program the Auto S/S kill switch
    Connect a button style switch to each of the white and green wires as shown and connect a LED and series resistor to "see" the pulse signal.
    Programming Procedure:
    1. With the power switch off, hold down the two buttons, then turn-on the power switch and release the buttons. The LED will illuminate for 3 seconds to indicate that the device has entered the programming mode. Keep the power switch turned-on for steps 2, 3 and 4 of these procedures
    2. Set T1 period: Hold down the button that is connected to the white wire for about 5 seconds. Release the white wire button and the LED will extinguish
    3. Set T2 period: Hold down the button that is connected to the green wire for about 2 seconds. Release the green wire button and the LED will extinguish.
    4. Set Mode: The last step is to set the MFDT to Delayed Interval (single cycle) mode - this provides the timing sequence shown in post #1 of this thread. The code for this mode is 7. To set the mode, momentarily press and release the two buttons together - the LED will flash to indicate that you have entered mode selection. Press the white wire button seven times to set mode 7
    5. Turn-off the power switch - the MFDT is now programmed!
    To test the correct timing periods, turn-on the power switch and observe the LED operation.
    If T1, and/or T2 need to be re-adjusted, repeat the steps outlined above. (note: there is no need to complete step 4 again - once the mode is set initially, it will remain at the set number).
    That's it - Remove the device from the programming circuit, remove the two buttons and secure the unused wires neatly so that they don't short against any other components. Then slip the completed Auto S/S kill switch into a piece of heat shrink tubing and install in the car.
    Installation:
    Mattaus will describe the installation of the "test device" in his mk7 which has additional buttons in the centre console, but in my MY13 model, there is only one button on either side of the gear selector lever. This means that the T15 power supply wire (Black/Yellow) is not in the wiring loom for the 10 PIN connector to the switch module.
    For those in this situation, the additional T15 wire needs to be provided and I found that the most convenient method of doing this was to install a "piggy-back" fuse on fuse position #40 in the "C" fuse box (which is located behind the glove box for those cars that have the steering wheel in the correct side).
    Given that I needed to work in the "C" fuse-box area anyway, and because access to the centre console is such a PITA, and because I'm still not certain that the time periods for T1 and T2 are correct (it's therefore likely that I will need to take-out and re-install the device), I decided to mount the Auto S/S Kill switch in the "C" fuse box as well (instead of the cavity in the centre console). To do this, I spliced the two wires to PIN #1 and PIN #4 on the 10 PIN connector and extended these into the "C" fuse box area.
    A picture of the complete installation is shown below (note: to minimise the possibility of the device rattling, I wrapped the the completed unit in "bubble-wrap"):
    So far the device is working perfectly albeit, I 'm tempted to reduce T1 to about 3 seconds. I'll wait for feedback from Mattaus and AJW before making this change
