halfmillion: What an excellent device -it's exactly what I was thinking of doing, but couldn't !!! Big kudos to the inventor.
Can you still get the parts for this unit? If so, I'm more than happy to build it for you
Yes, I suspect that SloAu is referring to either the Voltage method tweak, or the Temperature method tweak for disabling Stop Start. It's an OK method if you only want to disable SS and if you are prepared to tolerate the "tell-signal" on the MDF every time that the car stops
