Results 1 to 8 of 8
Thread: MK7 Swaybar sizes
    Nov 2007
    MK7 Swaybar sizes
    Confirmed Stock Rear Sway Bar Sizes for MK7/7.5 Golfs
    TSI - 19mm
    GTI non DCC
    GTI PP - 21.7mm
    GTI DCC
    R - 21.7mm
    Front or rear sway bar?
    I can measure the rear bar on my Mk7 GTI PP tonight if you want.
    It would make sense for the GTI/R to have a thicker bar than the TSI models.
    Jan 2017
    melbourne
    awd version has a different shape of rear sway bar to pass rear diff
    Nov 2007
    Rear sway, yes.
    I assumed the AWD would be different due to the diff, however numerous sites list the upgraded sway bars as fitting both FWD and AWD
    This coming long weekend I'll have a look and confirm. Both cars are going up on the ramps to anyway
    21.7mm on the rear of my 2015 GTI PP - checked it this morning with my verniers.
    Nov 2007
    Thanks Lucas
    Nov 2007
    Confirmed my R's stock bar is 21.7mm.
    Had it up to check/tighten the bolts on the Whiteline RSB (& links) yesterday.
    Nov 2007
    Confirmed the TSI's rear sway bar is 19mm.
    Also, the shape of the R and TSI sway bars are markedly different, and whilst the R bar will bolt up to the TSI, it then obstructs the exhaust. So, R sway bar will not fit the TSI. Sunday afternoon well spent ... learning yes, outcome not so much
    Attachment 51499
