Results 1 to 2 of 2
Thread: Stuttering and lurching
    Apr 2022
    New Zealand
    2013 golf 1.4tsi high line DSG.
    I’ve been noticing recently that when accelerating up to and cruising along at about 50kmh the car has a gentle lurching motion as if it wants you to keep accelerating, it causes a gentle rocking motion that is strong enough to feel. The car is in 5th gear when it does this.
    Yesterday, I also noticed the acceleration was really funny when accelerating from 60 to 100kmh in 6th gear, it seemed really juddery and when you looked at the rev counter it didn’t moved smoothly, it kept jumping up in stepped intervals of say 200rpm until I eased off the accelerator and it changed up to 7th gear to cruise.
    I have in the last 6 months had a new clutch and also the gear selector rods replaced.
    TIA. Nathan
    Nathan: Hi
    My advice - save yourself the angst of guessing!! There's a much better and generally a lot more accurate method for identifying the cause of these sorts of problem; "use the force Luke" - or in this case, use the in-built, self-diagnostic facility that was designed exactly for this purpose.
    Of course, you need access to a diagnostic device like VCDS, or OBDeleven
    If you don't own such a device - this forum has a "pimping service" that connects consenting members (albeit, I'm not sure how many potentially "consenting members" live across-the-ditch). See link below:
    VAG-COM scanning, who can help
