Page 65 of 68 FirstFirst ... 15556364656667 ... LastLast
Results 641 to 650 of 674
Thread: Golf Alltrack
  1. #641
    Now THAT'S how you Alltrack:
    Golf Alltrack-corner-jpg
  2. #642
    Pacific Paradise QLD
    Quote Originally Posted by Rooboy View Post
    They are still making it but I doubt we'll see the tdi Golf Alltrack here again. The Passat Alltrack is the last regular type diesel car being sold here at the moment but it's no longer available to build and price on the VW website. If you want VW diesel from now on, it's the Touareg, Amarok or one of the commercial vehicles.
    What about the 4 Tiguan Diesel versions
  3. #643
    Quote Originally Posted by mGlacius View Post
    Y
    On a side note, am I not seeing things, or does the Golf Alltrack does not come with a low washer fluid warning indicator?
    I noticed reservoir was dry this evening, and out of curiosity, I referred to the owner's manual to understand how to troubleshoot.
    The reservoir is tucked in deep, so you can't really tell how much washer fluid you have left.
    I'm guessing the indicator is for the Golf GTI/Golf R.
    You do check it every week when you check you oil dont you??????
  4. #644
    Sep 2012
    Only the 132 and 162 tsi engines listed for Tiggy on the VW website.
    Sent from my HTC 2PZF1 using Tapatalk
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  5. #645
    Adelaide hills, SA
    ...and that’s because VW Australia doesn’t want to have too many options. Maybe they change their mind after they lose customers.
  6. #646
    They must have just canned them then as I was offered the choice of petrol or Diesel 6 weeks ago
  7. #647
    Sep 2012
    Probably 2018 models as the diesels weren't included in the 2019 pricing and model announcement back in December.
  8. #648
    Probably as the one I bought is a Nov build
  9. #649
    Nov 2006
    Canberra, Australia
    Hi all, long time no post here on VWW.
    My partner is looking at buying a second hand Alltrack. Budget somewhere between 25–30K. A quick scan of carsales indicates that should get her a 2017 7.5 132TSI base model. I'm a bit out of the loop on specs, so if anyone can let me know the difference between the base and premium models. She's a bit no frills and would generally choose cheaper over higher spec, she's not too fussed on leather seats, for example.
    Next question, are there any issues to keep in mind? Is the 6spd DSG problematic like it can be on other older models, or has VW pretty much sorted that all out now?
    I assume the 4motion would be Haldex V, or maybe even something later?
    TIA
    Liam
    MY10 S3 3dr
  10. #650
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Lima View Post
    TIA
    Liam
    Its been a while since i got my alltrack
    Can't remember the difference between the 2, lights maybe a few other bits
    Tho the 6 speed is the wet clutch dq250 solid and reliable just make sure if it's done 60,000k it's had its oil and filter done
    Great car she will enjoy driving it
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
