Yeah the 135kw tdi is a great motor
But diesel is on the nose in the eu and us atm so it's no great surprise but still disappointing
BP diesel for me too.
By the way, Kachingg, where did you source your stiffer rear swaybar from, and approx cost, and did you notice any deterioration in ride quality? I have no issues with the handling, but a bit less understeer could make it a full-on fun machine.
I've just fitted a pair of front window (tinted) weathershields, sourced from Ferntree Gully VW, approx cost delivered about $100, and I fitted them myself without difficulty. I noticed a small increase in noise levels at highway speed. I've since taken them off and stuck some black contact to the inside horizontal (upper) part of each weathershield to block out some side glare from late afternoon sunlight. Now that I know it works, I would use black paint next time. Only cover the upper part though, to avoid obscuring side vision.
I have also used texta to black out the silver side air vent surrounds to eliminate annoying reflections in the side mirrors.
Hey Toomanyvw
I used a whiteside swaybar and linkages it tightens up the rear nicely i thought i would have to spend thousands on a good quality coilover set up to make it handle well but just $600 fitted fixed it
It was about 200 each for the swaybar and linkages plus 200 for fitting just be aware they had to modify the bar a little (with a hammer lol) to make it clear the driveshaft otherwise it touches it going over bumps
I had it set up firm and have noticed no deterioration in ride quality but the back no longer leans over and there is no understeer took it up the refton spur last month and had no issue with pushing several gti's along
I used otr motorsport in springvale Roy is excellent and already having done one would have no problems fixing yours
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
Tomorrow’s the day! Picking up the car from the dealer tomorrow.
Thanks everyone for your thoughts in this thread.. looking forward to driving the Alltrack!
Gratz
Enjoy your new toy
Lots of photos to come i hope?
I spent nearly the whole day sitting in the car itself..
I've got so much to say. More often than not, I'm impressed by the car more than anything else. Except they've done some changes in the MY19.
It's a nuisance getting to the speed limiter option now as you need to manually activate it from the Active Info Display as VW removed the hotkey on the steering wheel. VW assumes the driver uses ACC by default.
Managed to do a few changes to the car yesterday.
Didn't realise that the OBDEleven instructions I gathered over the months differed on my make. I'm guessing they've updated the platform?
There's quite a bit of stuff that I don't remember in which I don't need to code via OBDEleven. (Traffic sign recognition still required. I didn't need to do Light Assist..).
The only hurdle I had yesterday that threw me off by a few hours was to get my number plates transferred over to the new car.
Thank goodness delivery was early in the morning for me.
I managed to start working on the changes at about 3-4PM, and started again at 10PM-12AM yesterday.
I was in the car since post delivery and have already burnt 3/8 of the tank...
I've also swapped the stock mirror indicators to the Dyna blinks last night.
One of the first few times performing hardware related changes. (I'm not too savvy in handicraft..)
Pictures & videos below - thanks to everyone in this thread for their thoughts and contribution!!
Car came with:
1. Paint protection
2. Ceramic tints on all windows. Front has 35% VLT, rear windows have clear tints. (Yeeeeeah!!!!)
Changes:
OBDEleven tweaks.
Cargo light swap - halogen to LED CAN-bus compatible globe.
Mirror indicator - swapped from stock to dyna-blinkers. (This took me more time than expected at night).
I haven't swapped the fog lights to LED just yet.. I think they changed the design of the Mk7.5, so I need to read on how to replace it.
Incoming photo spam!
(I arrived 6 minutes earlier for the delivery, and I witnessed the car before it covered for presentation. Took a photo with my previous car before I left it..)
Videos of Changes:
Dyna Blinker
Before (with stock indicators): YouTube
In Progress (Test of Dyna Blinkers before reassembly): YouTube
In Progress (Fitted mirror caps back on): YouTube
After (with Dyna Blinkers): YouTube
Lock with acoustic feedback (OBDEleven):
YouTube
Good stuff! The dynablinkers look good. There seems to be regular changes to the platform coding. Kachingg and mine were only built a month or 2 apart but have slight variances in them even though they are both MY18 builds.
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
