Page 55 of 68 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 674
Thread: Golf Alltrack
  1. #541
    Sep 2012
    I can't say for sure but it might be a lazy dealer. It wasn't on mine at delivery.
    Sent from my HTC 2PZF1 using Tapatalk
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  2. #542
    I have noticed it is not on some / not all the wagons on carsales !
    May be the case they think I may want to change to Euro plates so have kept it there for its intended protective purpose ... could have at least asked me. I could always tell them to remove at the first tyre kick service. Thanks Rooboy.
    RS
    R
  3. #543
    Jun 2008
    I timed my alltrack yesterday and with my big wheels, the car reach 100km/h in 7s flat! What a suprise!
  4. #544
    Apr 2017
    belgrave victoria
    Yup they are quicker than you think
    Also if you replace the rear swaybar and linkages they handle excellent as well
  5. #545
    May 2017
    Tasmania
    There are a couple of perforations on each side to adjust to various width plates. You can see them on the black car in your pictures. The foam just peels off. I found that rolling it off by pushing it along works best. Then some citrus cleaner to get rid of any remaining stickyness
    Quote Originally Posted by Tuan View Post
    Hi guys, noticed that the Alltrack has the foamy rear number plate backing as well - if you left your standard plates on as opposed to wasting $400 to get bigger Euro plates, how did you go about getting rid of the excess backing ? Does it just peel off ?
    Thanks Alltrack guys.
    Attachment 35061Attachment 35062
    2022 Tiguan R Reflex Silver
  6. #546
    Thanks GolfAus ... thought that might be the case but just wanted to see if someone else had a go at it first at home
    RS
    R
  7. #547
    Asked dealer and they said they don't touch it .. lazy buggers. Time to pull out the citrus cleaner for the long weekend
    RS
    R
  8. #548
    Apr 2018
    Strathfield, NSW
    Joining the Golf Alltrack family very soon! Delivery sometime in early/mid-Nov 18.
    Shoutout to both kachinggg & Rooboy for posting stuff around their cars - saved me quite a bit of time on researching.
    Rooboy, would you happen to have have the steps on enabling Light Assist (auto high beam) on the Alltrack?
    I found the steps in AutoInstruct (for Mk2 Tiguans) & R-Line High Beam (Tiguan).. Though they're all on the MQB platform, they should work in theory.
    I thought there wasn't a difference between Dynamic Light Assist and Light Assist!
    I haven't worked on OBDEleven before, but I think it will be straightforward.
    Things I'm intending to change/activate via OBDEleven when I get the Alltrack:
    5 x Indicator Soft Touch
    Active Info Display Theme Changes
    Auto Daylight Savings Time Change
    DRL Option in MIB
    Easy Seat Entry & Exit
    Fan Speed in A/C Auto Mode
    Heated Seat Memory
    Lap Timer Activation
    Light Assist (High Beam Assist)
    Live Traffic
    Refuel Amount in Cluster
    Traffic Sign Recognition
  9. #549
    Apr 2017
    belgrave victoria
    Just been for a drive through the refton spur can confirm a tuned diesel alltrack will munch a stock gti
    Drive was heaps of fun lots of good blokes
  10. #550
    Sep 2012
    Congrats on the purchase! What colour did you order?
    I'm guessing yours should be a MY19 which means there might be some variances in coding due to possible hardware/software upgrades in the update but most on your list should be easily doable.
