How much did the vw dealership service cost rooboy?
I am getting my between service oil and filter change tomorrow every 7.5k now
Printable View
$310 for the first one. Got a replacement Golf to run around in for the day too...just not used to inserting a key to start anymore [emoji23]
Sent from my HTC 2PZF1 using Tapatalk
Yeah i have issues with the key now just so used to leaving in my pocket
Not bad for a 1st service see what the later ones cost!
$256 for my oil and filter change at 22.5k the price of power lol
Current pricing for book servicing is
30k/24mth is $506
45k/36mth is $558
60k/48mth is $623
75k/60mth is $310
Hi All,
Just a quick update if someone finds the same problem with the LED headlights. Went in to drive the Allspace Tiguan for the GF, and also spoke to one of the mechanics. He checked the settings, rekoned it was set for the wrong side of the road....woohoo thinks I - a solution. Wrong! Not only was the light more woeful, the cornering function is all but disabled. I now know this is normal behavior when you change from standard to opposite side in the menu. Anyway....he did also show me where you can manually adjust the headlight on the headlight unit.
The 30k service came up, I asked them to realign the headlights, not expecting any change, but not only was the service $100 cheaper than they quoted - the headlights are massively improved! The light is a little less focused up close but I am more than satisfied with the standard beam throw now - much improved :) So headlight alignment has solved the problem.
When we picked up the Tiguan, the salesman made a comment about the headlights (also LED) should be fine this time round.....but they are worse! So 1st service...align headlights please! The problem is not really evident on roads with streetlights, but on unlit streets, of which there are plenty around my area, it is truly scary - especially as many of those streets have no gutters, and telegraph poles are literally at the edge of the road surface on a couple of the roads I regularly travel.
The Allspace has the high beam assist....which I was nervous about using. Its just very alien leaving high beam on with approaching cars....but so far no-one has flashed me with the system activated! ....on the occasions I get to drive her car :)
I've replaced the tyres on the car....how lucky (sarcasm) front left outside edge was worn, front right inside edge was worn and rear tyre had a nail in the sidewall...grrrr. 29000km out of them.....not really good enough. I've changed them for Bridgestone RE050A which I had great success on another car....I must admit they don't seem as sharp as the stock Goodyear tyres...but they have great grip. Only done 1000km on them so time will tell.
Fuel economy continues to be good, long term average up a little to 6.4, but I've kind of given up chasing hugely low fuel economy and just enjoy the car!
Thats all!
Ash
Hi all, i have got the audi wheels on the alltrack now, but the vw hub caps are slightly smaller to fit, anyone have an idea any vw hun caps can fit?
