Page 51 of 68 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 674
Thread: Golf Alltrack
  1. #501
    Sep 2016
    Michelin Pilot Sport 4S tyres (4S not just 4) are the new sweet spot in high performance tyres. Almost as good grip as Sport Cup 2 tyres but quicker warm up for grip, better tyre life and cheaper than PSC2 and about the same price as Contis. Exceptional tyre that you cant go wrong with
  2. #502
    Sep 2012
    When your ski boots match your car...in name anyway...Golf Alltrack
    Sent from my HTC 2PZF1 using Tapatalk
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  3. #503
    Sep 2016
    Quote Originally Posted by Rooboy View Post
    You need some fluoro green stripes on your car now... clearly 👍😎
  4. #504
    Sep 2012
    Quote Originally Posted by LibraR View Post
    You need some fluoro green stripes on your car now... clearly Golf AlltrackGolf Alltrack
    Hmm flouro green go faster stripes...
  5. #505
    Jun 2008
    How is everyone feeling on the mode selector? I tested sport mode and normal, basically there is no difference in performance n fuel economy...
  6. #506
    Sep 2012
    An Alltrack brother at Falls but the 132tsi. And my car this morning...
  7. #507
    Mar 2017
    Tasmania
    Quote Originally Posted by hkogti View Post
    Well, how did you ‘test’ it? Performance mode does not magically increase the engine output. It will change the shift points for the transmission (basically, hold a lower gear for longer, shift down earlier etc). Not sure about the golf, but on the Passat Alltrack Wolfsburg (adaptive suspension etc) it also changes the damper calibration, steering feel, ACC, and climate control intervention (sacrifices the aircon compressor cutting-in when larger accelerator applications are made for example).
    The point being to make the car ‘feel’ more responsive - but it wont make it any faster.
    Nov 2017
    Coffs Harbour NSW
    DSG mode? I do between D and S for sure. Car feels quicker due to changes in shifting and will use a smidge more fuel due to higher revs.
    For the driving profiles, not so much. Just the feel of the drive as they really only change the steering, dampeners and sound. Sport mode does allow for a more aggressive Adaptive cruise control profile, so the car is harder on the braking and acceleration.
    For me I find the biggest impact just comes from me. If I drive hard in normal the car lets me just as it would in sport. If I'm a granny in sport the car goes along with me (assuming I switch the DSG to D as well)
    Eco mode is the exception as enables E mode for the DSG which allows the car to shift into N to coast, up shifts much earlier and downshifts quite late, so feels much slower. it also limits convenience consumers like Air Con and some lighting options. I think it also disables the soundaktor to encourage you to drive in a boring eco friendly manner. Again it's how you drive that really determines economy. Eco mode just helps that little bit more.
    Wow, under a blanket of snow suits an Alltrack IMO.
    2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
  9. #509
    Apr 2017
    belgrave victoria
    I do like the change from D to S with the dsg especially as i have had mine tuned its better in d and perfect in sport still takes the throttle into consideration but prod the throttle and whoosh your into the correct gear to slam into the corner
    The only way to make this car better is to put the golf r motor in it
    Untill then i will ride the torque
  10. #510
    Jun 2008
    Thanks for the input, i test it via driving the same route and same style, and i found no difference in performance, such as engine response, shift pattern (driving both mode with dsg in d mode), cant even feel difference in steering weight...
