They are not the current ones with the wide paddle like the mark 7 gti they are smaller and more rounded the ones you attach with double sided tape do not fit nor do the pinalloy ones which use small screws top and bottom to attach
I love changing with the paddles but they are 2 small to be easy to use Harding performance has a replacement anodized aluminum set but i don't know if they will fit (also costly at $350) i have to send them a photo of my paddles and they will let me know if they will fit
I am getting some more stuff from them next year so i am going to wait till then and get it all done at the same time
If you find some that work please post your results i for one am definitely going to get it done as the gtd motor we have in the alltrack loves to rev (variable valve timing helps) just needs another say 30kw and 80nm!
