So its not a constant 4 wheel drive ?
Only comes into play when the front wheels spin looses traction ?
Same as the Tiguan i have 130 TDI 7 speed DSG ,Then the 4 Motion cuts in engaging the rear wheels ?
Printable View
Yup its the Vw Haldex AWD system 95%+ power to front wheels till slippage then redirects power to rears newest mark 5 Haldex system (as fitted on the new alltrack) is vry good and doing it this way saves fuel as its frontwheel drive most of the time
If it's anything like the system fitted to the Mk7 Golf R (which I assume it will be), it is so intuitive in the programming that the Haldex is already sending power to the rears based on lots of things like throttle position, steering wheel angle sensor and the like to premept when power will be needed at the rear before the front wheels lose grip. So it "knows" when you are ripping into a corner, for example, and starts sending drive to the rears. Pretty much foolproof, and not once in the R have I felt that it is a FWD with a little bit tacked onto the rear wheels.
It is quite simply brilliant, and a quantum improvement even over that put in the Mk6 variants. If the Alltrack has that, it will be perfect!
Big thanks to moderator AdamD
Got the courage to up and book in a tune for my new alltrack when it arrives
Also got a set of 19 inch 40th edition rims and a big brake setup to go with it
So will be picking car up from dealers and dropping it off to be modified lol
Attachment 29235Attachment 29236
Going lower?
What are the outputs for a tune of the diesel?
Not planning to go lower atm just about out of cash after everything
will keep it in mind if i think the look will be better
Going to be using fast stuff in mordialloc (melbourne) had a chat with the boss (you can tell he loves his cars)
going to get a dsg tune at the same time output is not crazy want to keep the car for 10 years
Factory is 135kw and 380 nm after tune should expect approx 155kw and 450ish nm
So almost gti omph with a tdi 0 to 100m is 7.8 stock expexting to shave 1 sec off that and no traction issues or wheel hopping in wet with 4motion
Using the 19 inch wheels with 35 sidewall cause i never intend to go offroad (like 90+% of people who will buy it)
The big brakes are mainly for show as i hate the look of big open wheels with small brakes inside
that said it will be nice to be able to stop on a dime if needed
Faststuff said that if you really need to stop with those brakes will need to peel yourself off windscreen after lol
Picked up a 2017 MK7 (not 7.5) Alltrack with sports luxury pack for $36.5k driveaway. Showroom demonstrator with only 15km (so basically brand new). Decided the extras in the facelift are not really worth the wait/extra cost for me.
Coming from a MKV R32, the Alltrack still seems to have plenty of go based on my test drive. If I need more power, can always get a JB1/JB4.
Well done you resisted the urge to splurge hope you get lots of enjoyment from it
Still 3 mths to go for me 🤐
Hey guys
I am getting a alltrack but want to replace the crappy silver wing mirror caps with carbon fibre ones are the mirrors the same on all the 7+7.5 series? i can order some from overseas but want to get the right fit 1st time as its rather expensive to get the wrong ones
