Thanks AdamD
i will have to see if i want to risk it maybe a dsg upgrade will help with the extra torque
Thanks AdamD
Thanks AdamD you have got me energized for a tune again
Will have to find a good tuner in dandenong area melbourne now have heard good things about fast stuff in Mordialloc dunno if they do diesels tho will give em a call
thanks again![]()
My inlaws in Tasmania have just bought a Red Golf Alltrack
She told my daughter that its a 4 wheel drive ,i thought it was the same as my Tiguan 4motion
i searched the broucher ,no mention of it being a 4 wheel drive ?
https://www.volkswagen.com.au/en/mod...-alltrack.html
Yup it sure does
Just under where it says SHOPPER/CAMPER/SURFER TYPE
mentions 4 motion awd
Tell them gratz on the car btw in red 2 like mine tho i went diesel so still 4 months to wait
So its not a constant 4 wheel drive ?
Only comes into play when the front wheels spin looses traction ?
Same as the Tiguan i have 130 TDI 7 speed DSG ,Then the 4 Motion cuts in engaging the rear wheels ?
Yup its the Vw Haldex AWD system 95%+ power to front wheels till slippage then redirects power to rears newest mark 5 Haldex system (as fitted on the new alltrack) is vry good and doing it this way saves fuel as its frontwheel drive most of the time
If it's anything like the system fitted to the Mk7 Golf R (which I assume it will be), it is so intuitive in the programming that the Haldex is already sending power to the rears based on lots of things like throttle position, steering wheel angle sensor and the like to premept when power will be needed at the rear before the front wheels lose grip. So it "knows" when you are ripping into a corner, for example, and starts sending drive to the rears. Pretty much foolproof, and not once in the R have I felt that it is a FWD with a little bit tacked onto the rear wheels.
It is quite simply brilliant, and a quantum improvement even over that put in the Mk6 variants. If the Alltrack has that, it will be perfect!
