Page 13 of 68 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 674
Thread: Golf Alltrack
  1. #121
    Jul 2016
    Don't do it. They are ****e. Good for the first 3mm and heartbrake after that.
    Get some Michelin PS3 or Primacy 3 - around $235 or Goodyear Eagle Efficient Grip (will be similar to what you've got) for $300 each.
    If you still want Pirelli, give Tempe Tyres a call. They are usually cheapest in Sydney for Pirelli
    Oh... Anyway the P Zero didn't go through. They didn't have the right ratings. I might check out Tempe tires. Thanks!
  2. #122
    Erskineville, NSW
    What load & speed rating are the original tyres?
  3. #123
    Jul 2016
    95W...
  4. #124
    Erskineville, NSW
    Quote Originally Posted by helium777 View Post
    95W...
    Michelin Primacy 3 ST 95W (you could also use a Y speed rating) $235 each they have 4 in stock
  5. #125
    Jul 2016
    Thanks.. It's all settled...
    Now the spare R18 tire... hmm....
  6. #126
    Nov 2015
    A point on the Pirelli's- the "P Zero" name covers a number of differing model tyres from Pirelli. Some supposedly not so good. I've got the P Zero Asimmetrico on my Kizashi and they're a good tyre, a big step up from the stock Yokohama low noise/ fuel efficient tyres.
  7. #127
    Apr 2015
    Gold Coast, QLD
    What gearbox is in these alltracks? It it a reliable wet one or the troublesome dry 7 speed?
  8. #128
    May 2010
    SA
    As I read from, They are dq250. Same as golf R.
  9. #129
    Apr 2012
    Newcastle, NSW
    Anyone with Golf Alltrack and VCDS that can scan for me please...?
    Hi All,
    I live in the Skoda Octavia and Passat B7 sections (and the Polo section before that..).
    In Australia, our Octavia Scouts do not come with offroad mode, despite it being activated in the UK.
    Asking a favour from anyone with a Golf Alltrack and VCDS to do a scan for me please? The modules i need scanned are Auto trans (DSG), ABS, the central electrics, the AWD and the stereo. I need both the coding and adaptation channels scanned.
    If you have an Alltrack but no VCDS and live in Sydney or Newcastle and are ok if i scan it, please let me know.
    Thanks in advance!
    2012 VW Passat Alltrack 125TDI
    2014 VW Touareg V8 TDI Rline
    I Have VCDS if needed in Newcastle area by anyone.
  10. #130
    Aug 2016
    Hi All
    Can anyone explain to me if the headlamp cornering lights work on the Golf Alltrack and when do they come on?
    I thought because it was a Bixenon lamp that the main headlight would turn but when I went to the dealership to have a look the headlamps they didn't seem to move about when the car started.
    There is also a halogen blub that points out sideways and I was wondering if that would ever come on when cornering too?
    I am not talking about the static fog lights that come on when you turn and signal at slow speeds.
