Page 12 of 68 FirstFirst ... 210111213142262 ... LastLast
Results 111 to 120 of 674
Thread: Golf Alltrack
  1. #111
    Jun 2016
    Hmmmm.... if thats the case I could be in trouble since my alltrack comes with 225/45/18
    Will do more reading before purchase. Thanks
  2. #112
    Erskineville, NSW
    Quote Originally Posted by VicLes View Post
    As I said, look on the overseas forums as they deal with this stuff more regularly than here. I've seen some amazing chain solutions on Briskoda.
    In the long run, you are probably better to buy a set of 16x6.5 rims and fit them with winter or proper snow tyres - probably 195/60r16. 2nd hand 16" rims are cheap - esp if they have some gutter rash. You'll get the rims for $100-$150. No rash are only $400 with tyres.
    16" rims fit over 312mm brakes. If you have 288mm you can go down to 15"
  3. #113
    Mar 2010
    Quote Originally Posted by AdamD View Post
    The traction control system in these cars is also quite quick and effective in the wet.
    Can't pull out of side st quickly in the wet with my GTI, spins the wheels and TC will cut power. Also the dreaded axle tramp is worse in the wet.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  4. #114
    Jan 2012
    Sydney, Australia
    Alltrack is almost perfect for my needs, if not for two things.
    (1) Space saver wheel - How narrow is it, could it be swapped out for a full sized spare without raising the boot floor?
    (2) When touring, can I put on 16 inch wheels (16x6.5) with higher profile rubbers instead? For a more compliant and puncture proof ride on B roads.
    Thanks
    MY12 Tiguan 132TSI + DSG
  5. #115
    Apr 2016
    1, yes thats what I have done
    2, I would believe so as the brakes disks have plenty of clearance (they're not that big)
  6. #116
    Jul 2016
    Hi all, not sure if this is the right thread to raise this. Need some help with my Golf Alltrack tire...
    I just gotten my front tire of my Alltrack clipped and required replacement. It's a original R18 tire from VW (Goodyear Efficient Grip Performance). It seems the local shops here doesn't have the same tire available. I tried calling VW but haven't got my reply yet.
    I originally thought I could just get some tire of the same specification but my local tire shop was adamant that it has to be identical which he doesn't have the stock. I supposed I like to know if it has to be identical tire or just any similar would do?
    Appreciate some advice... Thanks!
  7. #117
    Mar 2015
    Warner, QLD
    Golf Alltrack
    Quote Originally Posted by helium777 View Post
    You should run the same tyres with similar wear on the same axle, ideally, all 4 should be the same.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  8. #118
    Erskineville, NSW
    Legally you can run different brand / pattern tyres providing they are the same construction and size. If you intend to do this, you should put them on the back as it will give slightly more predictable handling.
    Best practice is to have matching brand, tread pattern, size, load rating & speed rating on the same axle (and preferably on all 4 corners).
    Unfortunately, you'll probably have to buy two tyres (and put them on the back).
    Have you contacted Goodyear to see if they can get you a tyre? VW has nothing to do with what the tyre makers bring in.
    What size are they?
    Do you have a photo of the damage?
  9. #119
    Jul 2016
    What size are they?
    Hi Brad,
    Thanks! I just thought no harm calling VW. Got in touch with a few local shops and Goodyear, they confirmed no stock for the tire. It was "stock" GY Efficientgrip Performance (I am assuming all car of the same specs uses same tire?) 225/45/R18 that came with the lux package. Was quite badly clipped on the inside wall due and I count my lucky star that the rim was relatively unscathed.
    Anyway, I finally got a call from VW before the day end and they recommended getting just as you said a pair. Quoted me for Pirelli PZero. As I don't know much about tire, I just gone ahead to arrange that with my local shop. Hopefully VW's recommendation is good.
    TT
  10. #120
    Erskineville, NSW
    Don't do it. They are ****e. Good for the first 3mm and heartbrake after that.
    Get some Michelin PS3 or Primacy 3 - around $235 or Goodyear Eagle Efficient Grip (will be similar to what you've got) for $300 each.
    If you still want Pirelli, give Tempe Tyres a call. They are usually cheapest in Sydney for Pirelli
