hello,
I received this car with a long coding with a lot of zeros.
I've seen that you can get the long coding from a generator,
but I'm afraid this ABS Module is too new to support this.
Can someone help me further?
So I need the long coding of my abs module.
I will add a scan of the abs down below.
Would love to hear from someone and kind regards,
Jerlin
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DE HW: 5Q0 614 517 AD
Component: ESC H25 0524
Revision: 00000000 Serial number: 63008000000900
Coding: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 77FD5EDBCECD4D37FE-8022
16 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0338 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
0398 - Control Module Incorrectly Coded
U1014 00 [137] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:56
8279 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8280 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8286 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8292 - Control Module Incorrectly Coded
U1014 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8299 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8306 - Databus
U1122 00 [137] - Implausible Message
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:37
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
8311 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 51559 km
Date: 2022.08.20
Time: 14:23:35
Can you plug in the old ABS module and grab the coding from that? Otherwise youre going to need someone with ODIS I feel.
