Results 1 to 10 of 20
Thread: Golf 7 R - High pitched noise from Glove Box area?
    Apr 2014
    Golf 7 R - High pitched noise from Glove Box area? [Video Included]
    I've had a very odd noise coming from the glove-box area intermittently, and I'm lost as to what may be causing it.
    The noise is produced at seemingly random times, including when I first sit in the car in the morning (without even starting the engine yet), while driving or even after coming to a stop and turning off the engine.
    I was able to get a video of it to help you guys hear it, any thoughts?
    Video:
    VW Golf R 7 - Whining noise from Glove-box - YouTube
    Central VIC
    Interesting, dont have that noise in my R. Sounds electrical. Back to the dealer I'd suggest.
    Apr 2014
    Quote Originally Posted by andrew7 View Post
    I'm going to the dealer tomorrow, but I'm just worried that because it is so intermittent they may just say they didn't hear anything!
    If it wasn't so loud it really wouldn't bother me but I can clearly hear it over the stereo when the whine is at its loudest.
    I have noises not dissimilar to what you describe when the engine is switched off. They last about two to three minutes and then silence.
    Apr 2014
    Quote Originally Posted by Brycem View Post
    Do you only hear it when after you switch the engine off?
    Yes. Do you get the noise on switch off?
    Apr 2013
    I get a whine on switch-off in my gti but I don't notice it when the car is running. I'm guessing it has something to do with the lights or electricals in general (if you turn them on when the car is off the noise changes)
    Edit: It doesn't sound anything like that video though so I think not everyone describing the switch off noise is talking about the same thing
    May 2012
    Chadstone, VIC
    It's completely normal. Nothing to be concerned about. I also used to get it on my scirocco R
    Quote Originally Posted by Jimi View Post
    Jimi; The whine noise on switch off that you have described is likely (IMO) the electric water pump cooling down the turbo charger. Turning lights on/off will change the speed of the pump because the additional electric load will drop the supply voltage at the point of connection to the pump (DC motor speed is sensitive to volts).
    But I think that you are correct - choC's problem sounds very different
    Quote Originally Posted by choC View Post
    Video:
    ChoC: I'm not sure if you are aware, but the glove box is extremely easy to remove on the mkVII. It's a simple matter of opening the glove box and pushing-on two small tabs (catches) at the top -either side of the back part of the glove box. It's useful to know how to do this because it's how you get to the main fuse panel on the car.
    Given the intermittent nature of the noise it might be worth removing the glove box and looking behind the passenger dash when next the noise appears.
