Results 1 to 10 of 18
Thread: Golf 2.0TDI total oil loss
    Jan 2014
    Narangba, QLD
    Question Golf 2.0TDI total oil loss
    So my wife's 2014 Golf Highline diesel left a bit of oil on the garage floor Thursday night and then on the way home from work yesterday the oil light came on (I had warned her to stop if it did). RACQ came and found total oil loss. Looks to be leaking from drivers side front of the engine but very hard to see where. Car was running perfectly prior to this and never a problem. It's done about 110k. Anyone else experience similar?
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
    Pacific Paradise QLD
    Did you check the oil to see how much was in it before driving off.
    Do you ever check the oil and coolant levels
    Jan 2014
    Narangba, QLD
    This is not a gradual thing. It left a large over the garage floor (over one night) and heaps more at my wife's work carpark. Also left a big puddle of oil where she stopped waiting for the RACQ. Oil hadn't been checked in about a month but it has never used any significant amount of oil.
    I wouldnt be driving that too far and would check oil before i do the only trip thats to the dealer
    HAs it been serviced recently and tool didnt tighten the sump plug
    Jan 2014
    Narangba, QLD
    As I said above there is zero oil in it, RACQ said don't even start the engine. It will be trucked to the dealer ASAP. Last service was about 5k ago so not that recent.
    Jan 2014
    Narangba, QLD
    So the dealer said that it looks like the "crank seal failed due to wear and tear", no idea of the total cost yet but about 3 hours labour just to find the problem. Not really happy if it was the crank seal and it only lasted 110k km.
    Quote Originally Posted by Jondalar View Post
    Did they do the timing belt/chain and /or tensioners which is due at 105k as they may have nicked the seal in the timing cover as about the only place it would be from
    Adelaide hills, SA
    Quite hard to do, since it’s not exposed.
    Jan 2014
    Narangba, QLD
    My wife heard from the dealer this afternoon, total cost estimated at $2300 now as the "timing belt" has to be replaced due to being covered in oil. Alternator drive belt is also covered in oil. It's annoying as the timing belt was only replaced 5k ago. They are trying to get VWA to cover some of the cost as this sort of thing shouldn't happen and the car has all VW log book service history. We shall see.
    Jul 2018
    Camden Sydney
    if the belt was done 5k ago then thats the cause of the leak , have a look on the invoice for seals when they replaced the belt
