Results 1 to 5 of 5
Thread: Getting the rear view camera to work with trailer assist
    Aug 2017
    Uk
    So With trailer assist and no rear view camera the camera is actually there it just has the video feed loom missing , went to vw and asked if they do just a video feed loom, they don't do any looms that's not supplied with the car, so got the loom out of my camera kit (the loom is for sale on UK eBay for £65) and cut away everything that was not connected to the video feed lead, plugged it in then ran the cable to the mmi, connected the white and black wire to the blue plug, you have to remove the quad lock, pull out the blue plug from the quad lock by moving the little lever that clips it into place, then there's 2 locking covers that you have to flip up (fiddly) and then the pins slot in
    Next is the obd11 bit
    Camera system rear view
    Long coding
    Then select the long code up in the top right corner
    Scroll along using the green arrows at the bottom of the screen till Byte 7 -parking mode (quer) select the box
    Press and hold the green tick
    Infotainment
    long code
    Scroll down to
    byte_19_rear_view_low
    Change to activated
    Then reset the discover pro by pressing and holding the on/off button until the screen goes off then back on again saying welcome to Volkswagen
    Also noticed the parking sensor screen is transparent (some people are complaining that it's black and can't see 1/4 of the picture)
    Hope this helps
    Hi
    You need Park Assist 3.0 with camera high.
    And mib2
    Regards
    Aug 2017
    Uk
    What do you mean? I said Descover pro which is MIB2, and trailer assist comes with camera high, it's just not connected to the MIB
    Quote Originally Posted by Jap View Post
    What do you mean?
    Requirements for VW Trailer Assist
    YouTube
    Aug 2017
    Uk
    I think you may have it the wrong way round, I have trailer assist from factory but not the camera, so I'm just putting out what I did to get the rear view camera working,
