MY16 GTI 40
It wont leak but will be a good spot for crap to build up.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
MIRSAD: Just checked my Golf mkVII and the plastic bit (behind the wipers) fits snuggly against the glass all the way from the driver to the passenger side of the car.
Mine is an my13 TSI, not a MY14 GTI like yours. That notwithstanding, I would definitely complain loudly (and with purpose) to your dealer. The dealer might try to run a bead of silicon along the gap, but I would ask to have it fixed properly.
You might even try discussing the problem with the inappropriately named Customer-Care folk at VW Australia. My past experience has been that such exercises are better described as "the delicious futility of an impossible task"! But, if you have the time and the internal fortitude for doing battle with a large industrial conglomerate -like VW, give it a go!
MY14 GTI, appears to be a uniform fit all the way along.
MIRSAD, I have the same issue as you, but what I did was I pushed the plastic against the glass. Not sure how long it's gonna last.
GTI PP Mk7
My grandma used to say...
Thank you for checking your cars
Unfortunately clipping back that plastic is not working on my car
MY16 GTI 40
Flushed on my GTI PP!
Mk 7 GTI PP
Should be flush, been like this since golf 5. It just clips in.
If you clip it in and it pops out its probably deformed from being unclipped so long. Id suggest a replacement trim
