Results 1 to 10 of 20
Thread: Gap between windscreen and plastic (5-6 mm)
    Aug 2009
    WA
    MK7 Golf - gap between windscreen and plastic (5-6 mm) - outside, drivers side, bottom about 25 cm long... as per below:
    Gap between windscreen and plastic (5-6 mm)-img_1511-jpg
    Gap between windscreen and plastic (5-6 mm)-img_1512-jpg
    only drivers side .... noticed few more MK7 Golfs with similar gap (I am sure it is not by design) can you, please check your car ... not sure can it result in water leaking
    MY16 GTI 40
    Jan 2014
    Burleigh Waters, QLD
    Quote Originally Posted by MIRSAD View Post
    What does the dealer say about it?
    Jul 2007
    Brissy
    It wont leak but will be a good spot for crap to build up.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2009
    WA
    Quote Originally Posted by flight View Post
    Didn't have chance to visit dealer - spotted on Friday night.
    any other MK7 Golf owners with similar gap?
    MY16 GTI 40
    MIRSAD: Just checked my Golf mkVII and the plastic bit (behind the wipers) fits snuggly against the glass all the way from the driver to the passenger side of the car.
    Mine is an my13 TSI, not a MY14 GTI like yours. That notwithstanding, I would definitely complain loudly (and with purpose) to your dealer. The dealer might try to run a bead of silicon along the gap, but I would ask to have it fixed properly.
    You might even try discussing the problem with the inappropriately named Customer-Care folk at VW Australia. My past experience has been that such exercises are better described as "the delicious futility of an impossible task"! But, if you have the time and the internal fortitude for doing battle with a large industrial conglomerate -like VW, give it a go!
    MY14 GTI, appears to be a uniform fit all the way along.
    Mar 2014
    Perth
    MIRSAD, I have the same issue as you, but what I did was I pushed the plastic against the glass. Not sure how long it's gonna last.
    GTI PP Mk7
    My grandma used to say...
    Aug 2009
    WA
    Thank you for checking your cars
    Unfortunately clipping back that plastic is not working on my car
    MY16 GTI 40
    AU
    Flushed on my GTI PP!
    Mk 7 GTI PP
    Jun 2011
    sydney
    Should be flush, been like this since golf 5. It just clips in.
    If you clip it in and it pops out its probably deformed from being unclipped so long. Id suggest a replacement trim
