Page 17 of 23 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 221
Thread: Fuel Consumption - How's THAT going ?
  1. #161
    Oct 2010
    I have found (and Gerrycan has also mentioned iirc) that ac makes a fairly large difference to economy in a 1.4 manual. Almost 1l/100 difference. I can drive in 60 zones around town (non peak) in the mid 5s, but ac bumps that up to low to mid 6s. Stop start bumper to bumper is low 7s now. Highway with ac is high 5s, no ac I reckon I could nearly get high 4s. Engine has loosened up nicely, about 3.5k on the clock and keeps getting better each tank. Gauge seems quite accurate (both fuel gauge and trip computer)
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  2. #162
    Aug 2013
    Hazel Glen
    Quote Originally Posted by Baz 55 View Post
    Comfortline 90kw 200nm petrol
    Usually drive in Eco Mode (DSG)
    2000k on the clock.
    Long Term 5.8l per 100km
    Last Tank 5.5l per 100km
    Driving - city / outer urban mix.
    Fuel 95 Ron (just found out I should be using 98 Ron (oops) Next tank
    Update - 20,000km on clock - same type of driving.
    Seems to be roughly 5.3 on average.
    Driving mostly in Eco mode and have become an expert on coasting !! lol
  3. #163
    Mar 2015
    Antwerp
    Comfortline 1.2L - 105bhp - TSI DSG
    Mostly used for commute to work which is 50 - 70 - 90 km/h roads
    on cruise control, lots of turning on small roads (50km's per day)
    6.4L / 100km on the long term (got 2000km on the car now)
    Always use the eco mode of the DSG and disable start/stop as soon as I leave home.
  4. #164
    Mar 2009
    Quote Originally Posted by Jimi View Post
    That sounds high, even for a tight engine. Give it another 1000-2000km and if it's not into the 8s for normal urban driving then there's something funny going on
    Also run ins shouldn't be gentle. Give it some stick asap
    Recommend running it in straight away, or after the first 1000km?
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  5. #165
    Erskineville, NSW
    Quote Originally Posted by Ralfi View Post
    straight away. You need to bed the rings in while the cross hatching on the bore is still "sharp".
    I'm not saying thrash the engine but for most people run-in has to be more vigorous than what their normal driving will be down the track. It's a really hard head space to get yourself in. My wife just got a new Honda & she can't get her head around it (partly because she is extremely stubborn and doesn't really give a crap about cars).
    I can't believe the number of people in this thread that use cruise control, eco mode, "D" mode and aim for fuel economy in the first 3000km. You are just setting yourself up to have a slow, tight, thirsty engine that will probably use more oil than it should.
  6. #166
    Mar 2009
    Ahh thanks. I asked because iirc, the engine in the Polo GTI needed to be run in after a certain number of km's had been reached.
    Different engines, different characteristics/demands eh?
    MY16 MK7 Golf GTI
  7. #167
    Erskineville, NSW
    No, they are all engines and can be treated the same.
    I'm not sure you have an understanding of what the term "run-in" means. You are running-in or bedding-in the engine (and all the driveline, brakes, suspension, etc) from the first turn of the key at the factory.
    You can run them in gently like my aged father does & have a slow engine that drinks fuel like a sailor on shore leave.
    You can run them in briskly but gently and they will spin nicely, get good fuel economy & last a long time.
    You can thrash the bollocks off them and they will do all of the above & maybe not last quite as long.
    I'm a middle-ground guy.
  8. #168
    Oct 2010
    Run in is most important in the first few ks. Vary load and speed and you should be right. I'm not trying for economy in any way, just commenting on the figures I get. I took it for a drive in the hills and used the firm run in method. Car gets a proper spanking every now and then also. All my vehicles get that and I haven't had a bad engine yet.
  9. #169
    Mar 2009
    Appreciate all the info, Brad.
    I'm not an enthusiast when it comes to cars (clearly), but interested none the less.
  10. #170
    Sep 2010
    Quote Originally Posted by GTR27 View Post
    I find driving into a head wind or driving in rain makes a bigger difference than air con to the economy. I regularly get around mid to upper 4's with highway driving sitting around an indicated 105 (because of the inaccurate speedo) A trip to Sydney and back with air con running all the time gave 4.5 one way and 4.6 the other. The MFD economy readout is usually around 0.2 optimistic. After 73,000km my long term MFD readout averages are always 5.3L/100km
    Nov '15 Polo 81TSI manual white
