I just replaced the pads on my 2015 GTI PP (had 48,000km on it at the time). The disks are still ok although I will probably replace them in the next 12 months. The pads still had some life left in them but the reason I wanted to change them was due to the excessive amount of brake dust.
I used ATE Ceramic pads, which although not cheap (just over $500 for all 4 corners) are very good quality and extremely low dust.
You just need to buy the Golf R pads and disks as the GTI PP uses the Golf R brakes. You can buy them from Harding Performance.
Front pads: ATE Front Ceramic Brake Pads - MK7/7.5 R, 8V S3 - Harding Performance
Rear Pads: ATE Rear Ceramic Brake Pads - MK7/7.5 R, 8V S3, MK7/7.5 GTI - Harding Performance
Front disks: ATE Front Brake Discs (Pair) - MK7/7.5 R, 8V S3 - Harding Performance
Rear disks: ATE Rear Brake Disc (Pair) - MK7/7.5 R, 8V S3, MK6 R, Scirocco - Harding Performance
Some pics here of my pad install if you are interested: My Mk7 GTI PP....turns out I cant resist the VAG.
