Im soon to buy a mk7 golf r
So it seems that if a golf r has lane assist and adaptive Cruise with the driver assist pack, that openpilot should work for autonomous driving.
I'm looking at a golf r but was looking a mk7 which I believe doesn't offer lane assistant in the driver assistant pack but would the camera be there still if it has emergency breaking... Although I believe that's Radar.
Anyone know about this... I wouldn't buy a mk7.5 with driver assist to just have this option of autonomous because im not sure I'd use openpilot...but if a mk7 had the camera and capabilities with openpilot then I'd give it a go
I'm refering to am aftermarket system called openpilot. Have a look. It works on golf mk7 with lane keep assist and adaptive cruise. It's an open source project that is mostly used on corollas but the Golf mk 7 is also being added. However it needs the camera and steering control components... I've read somewhere that sometimes the camera is in the rear view mirror mount on some cars without lane assist. Which is my hope to find out what years may have it.
Yes you can use a Mk7 or 7.5
Front camera is not required for either, but ACC radar is.
You need to jump onto the Discord channel and read up on the stickied posts. You'll need a custom made (or make your own) gateway Y harness to install (different depending on if you are using original Comma or new Comma2).
Just make sure it has ACC, and not just front assist (it still has a radar, but it's software locked just for emergency braking, no adaptive cruise)
