Results 1 to 10 of 12
Thread: FM station presents not being saved
    May 2018
    Sydney NSW
    I've recently bought a MY2015 R, and I've noted that the infotainment unit never saves the radio station presets that I make, when I restart the car. It is as if the battery has been disconnected.
    The infotainment unit seems to remember all other non radio settings.
    Feb 2018
    Fulham SA
    Not being smart... but are you actually saving them as a preset?
    MY15 GOLF GTi PERFORMANCE - CARBON STEEL
    May 2018
    Sydney NSW
    Yes I am. I am pressing an empty present button (there are 6 on each screen, each one labelled as Empty) and it saves the current station on whichever empty bottom I press. This renames the empty present button with the name of the station I just saved. But when I turn on the radio again after it has been off, the saved station are lost.
    May 2018
    Sydney NSW
    Just checked the manual for the head unit. Am definitely saving the stations the correct way, with an audible confirmation tone.
    Sep 2012
    Is there a separate fuse for the headunit memory? Have you tried factory defaulting all settings in the headunit? Or try rebooting it (hold down power button for 30 seconds or something)?
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
    Kevlarman: No the preset memory function on the MIB is not separately fused - but I agree that it's worth trying the MIB reset procedure - beacuse it's an easy try (and becasue it's the standard suggestion for ALL IT/Digital problems!! )
    Feb 2018
    Fulham SA
    Quote Originally Posted by LimestoneR7 View Post
    This would annoy the **** out of me! As others have suggested, try resetting the unit. Is there any factory warranty left on the car?
    May 2018
    Sydney NSW
    I'm not sure. Car is a 2015. Just bought as the second owner. Also this unit is a retrofitted MIB1 with 8" screen. It was apparently fitted by a VW dealer but I don't know it it would be under warranty even if the car itself is.
    I'm having absolutely no luck in updating the GPS maps and speed camera POIs. I read a while back on this forum before I joined that that was a Sydney based expert with the VW infotainment units, so I think I'll find out who that is.
    May 2018
    Sydney NSW
    I tried the MIB reset procedure*, but it didn't clear my settings. There is a factory setting option in the Menu and that did clear most settings (I know as I had to relink by pone via bluetooth). Unfortunately it hasn't fixed the radio station memory problem.
    *Can anyone confirm the
    MIB reset procedure?
    It is holding down the power button for 10 or 30 seconds?
    Should radio be already on before this is done?
    Should ignition be on or off?
    ^^^ yes that's how the reset procedure is done:
    Turn-on the MIB
    Press and keep holding down the ON/OFF button - the MIB will turn-off and it will then turn-on again
    When the MIB has turned-on again, release the ON/OFF button
    The MIB has been retrofitted? Sounds suspicious - do you have access to a diagnostic cable (VCDS, OBDeleven, or VCP)? If so, are there any error messages?
