On my GTI Performance I'm onto my third water pump. The symptom has always been low coolant levels as flashed on the instruments and the MIB1. The first water pump was replaced at 30,000km with a supposedly improved version. After a while the coolant level dropped again with appropriate warnings and this water pump was replaced at the 45,000 service. Apparently the leak came from the thermostat housing.
All fixed by the dealer under warranty and no issues (in 5,000km) since. A very common problems on R and GTI EA888 engines but not the 1.4 engines which apparently use the same water pump. Go figure...
Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
