Hey, not had any problems for a while and never had a fluid leak, until now.
On the timing chain side of the engine just below the bottom pulley I’ve got a small pool of clear fluid just on top of the plastic under tray and a small pool now on the floor. The fluid is clear but not water as it is thicker and seems lubricated.
Attached is a photo. You can just see the dampness on the plastic tray and the pool below. My first thoughts are break fluid but the reservoir is still full. Are there and other clear lubricate fluids on this left side of the engine?
