Results 1 to 3 of 3
Thread: Fix for creaking sunroof - clean the trailing edge rubber seal
    Sep 2008
    I've been trying to track down an intermittent rattle that only happens over very rough roads and sounds like it's coming from somewhere between the passenger side dash, glove box, sunroof, visor or B-pillar. Today I realised that the sound goes away when you crack the sunroof open every so slightly. Think four micro-presses - enough to just break the seal.
    The solution: clean the trailing edge of the sunroof rubber seal.
    Can anyone recommend a product to lubricate this? Perhaps something similar to what's used on the Eos roof??
    Cheers,
    David
    Nov 2014
    Lake Macquarie, NSW
    Quote Originally Posted by sucnip View Post
    Cheers,
    David
    Try using a silicone spray, probably best applied by spraying onto a clean cloth and then rubbing along the seal.
    Regards,
    Graham
    Jul 2007
    Brissy
    Gummi Pflege has proven to be a great product for conditioning rubber
    Einszett Gummi Pflege Stick
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
