Page 6 of 22 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 213
Thread: Fitting Folding Mirrors to the Mk7 Golf
  1. #51
    Apr 2011
    Same here.
    And without reading through the previous 4 pages, is this applicable to a TDI Highline? Or do I need more parts?
  2. #52
    Maribyrnong, Victoria
    No idea re Hi Line may need different door controllers... the parts were approx $750 to buy... not including the Hex Can cable I have from Rosstech
  3. #53
    Mar 2014
    Perth
    Fitting MK7 Folding Mirrors to Golf GTI
    This is really interesting. I might do this for myself,
    Do the left mirror dip when you reverse?
    GTI PP Mk7
    My grandma used to say...
  4. #54
    Aug 2007
    Great work, I haven't had a chance to do any further resarch for adaption of the navigation to bring up mirror options. it will no doubt be a coding issue.
    Lock the car by holding down lock and the mirrors fold on my golf r. If i lock the car by touch handle (golf r kessy) it won't fold on lock. It might be a bad idea to fold on lock as sometimes i park so close to things that it would smash my mirror if it tried to fold.
    *edit* just noticed that you had the grabby thing. We didn't have one, what a mission!
    Quote Originally Posted by peekay34 View Post
    Hooray in an finally working.... On the Performance Pack the controllers were required (can't speak for the standard GTI).
    The part numbers are correct Booba provided.
    Left Mirror 5G2 857 507 CA 9B9
    Right Mirror 5G2 857 508 AJ 9B9
    Switch 5G0 959 565 AA ICX
    A couple of things to the note the instructions from USP Motor Sport are correct. But the wiring to move the door skin on the drivers side is a little more fiddly ...I was upside upside down looking up the door..... you don't need to remove the door skin completely on either door (the door handle cable) just lay some cardboard down so the skin does not get damaged. Routing the cables can be a little difficult but if you get the grabby thing from supercheap auto and a magnet then is to hard.
    Important One thing to note..... do not try and fold the mirrors manually they are not spring loaded like the factory standard mirrors. You must use the Switch or the keyfob to lose them or you will break them. I followed the coding from USP motor sport not sure if Booba can add anything here. The manual says go to the Car Setup Mirrors but I can't see any thing will have another look tomorrow to Auto close them on lock.... I have to hold the lock button on the Fob for them to close or use the switch. Video and PICs attached. Last pic is the video.
  5. #55
    Mirror actions are the same as standard mirrors on your car
  6. #56
    Feb 2014
    This is truly outstanding peekay. All in all how long did this take you to complete?
    I also didn't realise the puddle lights come standard with the folding mirrors.
    Just to confirm, where did you order your parts from? Are they all from USP Sports?
    Driving: Golf R Mk7 MY14 - Pure White, DSG, Leather, DAP and Sunroof
  7. #57
    OK so an update all of a sudden my mirrors would no longer Fold in via my the remote after working for over a week. After hunting around I finally found something that helped and it is now fixed. Thanks to the finder of this on the other forum ......as I was left scratching my Head.
    So after hunting found some more coding that is required. You have two options to fold on Lock or Fold by remote. The USP coding instructions are not enough. Again you need a Ross Tech Cable....or simular. A full dump of this can be found at
    VWVortex.com - USP Folding Mirrors VAG-COM - Fold automatically upon locking - Instructions
    VCDS:
    Choose "Select control Module"
    [09] Central Electronics
    [16] Security Access - Code is 31347, click "Do it!"
    [10] Adaptation, choose from the drop down channel
    [23] - Access control 2 - Funk Spiegelanklappen change to "active", click do it
    [26] - Access control 2 - Menuesteuerung Funkspiegelanklappen change to “active”
    [24] - Access control 2 - Funk Spiegelanklappung Modus change to “by look command via remote control key” this will fold the mirrors on lock.
    [24] - Access control 2 - Funk Spiegelanklappung Modus change to “via convenience via remote control key” This will work ensure function works via remote (which is what I selected as I don't need them to fold all the time)
  8. #58
    HI Mate do not order from USP the offsets are incorrect and they will not function correctly....... Also the switch is wrong is for left hand drive cars...... IF you want them I got mine from South Yarra Volkswagen..... Adam ordered them
  9. #59
    Nov 2014
    North Sydney
    Well done Peekay34, great write up and effort.
    This is definitely on my list to do to mine.
    2014|MK7|GTI|PureWhite|DSG|Bi-Xenon|Leather|Driver Assist|Tint
  10. #60
    May 2014
    I ordered the folding mirror modules listed in this thread for my highline yesterday.
    thanks for the write up peekay34, I cant wait to try this on my car
