Page 17 of 22 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 213
Thread: Fitting Folding Mirrors to the Mk7 Golf
  1. #161
    Mar 2009
    Quote Originally Posted by monkeysrus View Post
    My car was already mib2 with blind spot, was just specific mirrors with the extra wires.
    Ahh, that's why. I thought you meant you installed the Blind Spot Assist (BSA) feature (& you didn't have it prior) as well as the folding mirrors.
    If you've already got the DAP then yeah, you can get folding mirrors with BSA, but if you don't have DAP, then forget about BSA.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  2. #162
    Dec 2015
    South Yarra, VIC
    Ralfi, can you supply the part numbers you required. My car 2016 Golf R with DAP2.
    Sent from my SM-G925I using Tapatalk
  3. #163
    Mar 2009
    Quote Originally Posted by mpierce View Post
    My part numbers are of no use to you, mpierce, because I don't have DAP1/2. My folding mirrors are sans BSA.
    monkeysrus' part numbers MAY be ones you want, but to make sure, contact VW Central - these part numbers need to be specific for your VIN number, which VW Central can check.......it's the best way to be sure.
    MY16 MK7 Golf GTI
  4. #164
    Dec 2015
    South Yarra, VIC
    OK... Thanks for quick reply!
  5. #165
    Dec 2015
    South Yarra, VIC
    Quote Originally Posted by VW Central View Post
    Depending on your VIN some cars support the folding mirrors without the need for upgrading door modules, unfortunately some of the newer Golf R's we have seen come with Door Modules that do not contain the correct PR-codes necessary to support folding function. We like to ensure each customer is provided with the correct honest advice. We simply don't want to just sell you Folding Mirrors & the switch and send you off on your way. Despite the revision being B,C,D,E they need to have the correct colour code associated. The later generation door modules also cost more than a revision B set of door modules for vehicles prior to November 2014.
    We charge a flat $200 for labour of the folding mirrors, which includes the VCDS coding.
    I hope this sheds some light.
    I have a 2016 Golf R, Chassis #WVWZZZAUZGW026265 in Melbourne.
    Which parts do I require?
    Can I order them direct from you?
  6. #166
    Apr 2009
    Sure can! We've sent you a PM.
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
  7. #167
    Jun 2016
    VICTORIA, SUNSHINE
    Hi mpierce,
    How did you go installing the Mirrors?
    I'm keen on doing the mod.
    Have been talking to VW but no luck with the parts numbers supplied in the previous posts.
    However, I got quoted on PASSAT MY15 R-line mirrors that fold and have puddle lights and lane change assist.
    Cheers,
    Chandi
  8. #168
    Dec 2015
    South Yarra, VIC
    I'm having them fitted this week. South Yarra VW special ordered parts from Germany. Took about 10 days for parts to arrive. Total cost with GST was a bit more than $700. I'll advise once fitted.
  9. #169
    That's good price!! I am very interested.
    Golf GTI MK7
  10. #170
    Dec 2015
    South Yarra, VIC
    Read thread to get correct parts. I have DAP II. Yours are different.
