Page 12 of 22 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 213
Thread: Fitting Folding Mirrors to the Mk7 Golf
  1. #111
    Nov 2015
    Im following this thread with interest guys. Would love to make this happen on my Wolfsburg wagon without losing blind spot indicator, mirror heater, reverse parking turn down, etc. It's quite amazing the amount of features and tech are packed into a simple side mirror these days!
  2. #112
    Mar 2009
    Quote Originally Posted by sparkyboy69 View Post
    Foldable mirrors appear to be ridiculously expensive. Quoted$1999 plus 5 hours labour to fit
    I was quoted about half that (I think that was including labour).
    That was months ago though, & the company has been through some management changes so not sure what it'd cost these days.
  3. #113
    Nov 2015
    Greece
    Hello, i am new member here,
    My Golf 1.6 TDI Bluemotion is about 9 months old.
    I order via ebay a set of genuine used folding mirrors, controllers, and switch.
    As i had already mirror dipping function i didn't replace the passenger controller and everything worked with that side.
    My old driver's controller was low spec 5Q0 959 393 D and i replace it with a 5Q0 959 593 B version(we have LHD in Greece).
    Right away i noticed some problems.
    1. orange led in lock switch did not work ( switch worked fine)
    2. Puddle lights did not work on the mirror
    3. My windows did not work most of the time. I turn the key off and back on and they worked fine, but i tested again after 10 min. they stopped working.
    I email the seller and VW told him that:
    "The problem is you need to go to the Vw store, they must put online coding of Both driver controllers ( 42 and 52). In odis you can say under interactive function " coding " than everything wil work only folding mirror not, but this you can code with vcds."
    His english is not very good but what does he mean by interactice function coding?
    Anyone know what may have cause this? I only suspect a faulty controller.
  4. #114
    Quote Originally Posted by RAINFALLGR View Post
    RAINFALLGR:Χαίρετε!
    The "mirror dipping function" that your car had prior to retrofitting the mirror items is very different to the folding mirror facility (the former dips when you put the car in reverse, whilst the latter folds/unfolds when you operate the keyfob/ignition cycle):
    So, from my understanding of your story, if you simply added folding mirrors to a car that previously didn't have folding mirrors, you will need to re-code the passenger and driver's side door control modules (@ hex address 42 & 52). For this, you will need to have access to a VCDS cable. It is entirely unnecessary to spend money at the dealer to use their ODIS - you can do all the changes with a VCDS cable
    You will find the complete set of instructions on how to do this HERE (the VCDS coding changes are near the end of the document)
    Prost
  5. #115
    Nov 2015
    Greece
    Thank you for your answer.
    I have a VCDS cable and did the coding. As my passenger's controller was high spec ( 592 edition), i did not replace the controller, just coded with VCDS cable and worked ok.
    My Driver's controller was low spec (393 edition) and i replace it wish a used high spec (593) controller. I coded with VCDS cable again but controller was acting very weird.
    Seller told that i need "ONLINE CODING" via ODIS. so today i visited my dealer. And coded the controller for my car.
    All the problems solved, but controller need again coding with VCDS cable. i recoded and everything is working fine.
    So for all the folks outthere that are planning this convertion keep in mind that if you replace the Door controller you need to go to VW and do a "online coding" via ODIS.
  6. #116
    Nov 2014
    ACT
    I have the following door control modules, would these work for folding mirror mod..?
    Passenger door control unit: 5Q4959592CZ03
    Drivers door control unit: 5Q4959593CZ03
  7. #117
    Oct 2014
    Quote Originally Posted by MRG_AU View Post
    I believe you do as the numbers matches up with what RAINFALLGR has stated ie Passenger door control unit: 5Q4959592CZ03
    How do you check what control unit you have? Must you pull apart the door trim?
    Current: 2015 Limestone Grey R Wagon DSG (MY16); Panoramic Sunroof
    Past : Steel Grey RS TSI Hatch 6MT (MY15.5); 19" Black Pack; Sunroof; Comfort Pack; Docked 04/03/2015; Delivered 26/03/2015​
  8. #118
    Nov 2014
    ACT
    VCDS Adpmap shows these numbers in control module 42 and 52
    ;SW:5Q4-959-592-C HW:5Q4-959-592-B --- Door Elect Pass. (52)
    ;SW:5Q4-959-593-C HW:5Q4-959-593-B --- Door Elect Driver (42)
    and the local dealer gave me the exact part numbers based on my VIN.
    I read RAINFALLGR comments, my understanding is if the last 3 digits are 5 series, especially 592 and 593 then they will work. I just wanted to double check. Now would these controller work with these mirrors LHS-5G2 857 507 CC and RHS-5G2 857 508 AK for MK7 highline with DAP2,am I in the right track....?
  9. #119
    Oct 2014
    MRG, sorry I can't actually help you out here since I haven't done this and am no expert at it either. On a different note, how much did Adam quote you for the mirrors and switch plus postage? I ask because VW Central (VW Central) is quoting $1000 for the parts.
  10. #120
    Nov 2014
    ACT
    Prices are in my earlier posts back in April or May , I was quoted same in Canberra yesterday. However quote to fit the mirrors is over 600. So once all confirmed I am doing it myself
    Regards,
    MRG
    2015 Limestone grey Golf 103TSI Highline with Luxury pack and Driver Assistance Pack II
    2012 Pantom Black Audi Q5 3.0 TDI with B&O sound system
