Results 11 to 20 of 21
Thread: first day with Mk7 auto - suggestions - stalled 3 times
    Adelaide hills, SA
    Quote Originally Posted by Sunday View Post
    Thanks all for your responses, I will contact the dealer tomorrow. Any tips? What am I likely to expect?
    I doubt they would be able to reproduce the issue on the spot.
    I wasnt sure if there was some button I needed to press but your responses makes sense, I figured it should just drive like any other auto. I couldn't work out if when I take my foot off the brake and its in first and I rev it hard it will changes gears too quickly and slip or something.
    In total there were 4 stalls in the bluemotion mode over a distance of about 100km. I drove around with this mode turned off turned off no issues.
    I wasn't willing to try and replicate the issue because I honestly felt scared. You know those quick right hand turns across traffic you have to make to find a gap in city traffic, was not willing to risk the thing stalling in one of those situations after 4 stalls earlier in the day. When I made those turns I wasn't feeling confident at all.
    Really frustrating because I was looking for a reliable car and finding it hard to justify taking a risk on a car I don't have personal experience and the first day it cuts out 4 times! The 17 year old legendary automatic I replaced has never stalled or not started once
    Do you use the left foot for braking? If yes, you have to make sure that you don't touch the brake pedal at the same time as the accelerator.
    Sep 2010
    It's a DSG so assuming the op has it in the default stop/start mode the engine will always be turned off when stopped, so what is happening when you do touch the accelerator again? Is it simply not restarting ? Or is it restarting and then stopping straight after?
    I have a manual like every car I've owned in the last 40 years and the Golf would have to be the easiest of all to drive with the sweetest most forgiving clutch ever invented. Driving schools will love it. I don't think I could stall it if I tried.
    Nov '15 Polo 81TSI manual white
    Pacific Paradise QLD
    Learn to anticipate the lights a bit and lift your foot off the brake just a bit till the engine restarts.
    Then when you fully release brake you can press the loud pedal.
    If you lift and press at the same time it wont like it as you need a few milliseconds for the clutches to grab.
    Have never had any trouble with mine. When driving locally I can drift up to the lights and hold it with the brake on enough to disengage the clutch but not hard enough to stop the engine. Only do it at lights which I am familiar with the sequence though.
    Just don't "creep" a DSG in traffic as that's the same as slipping the clutch in a manual and will eventually give the same result. One stuffed set of clutches.
    Apr 2011
    Hillbilly, are you describing what happens in your Passat TDI Wagon? (The same as my Alltrack).
    This thread is about the Mk7 Golf, and I'm sure it's different. However, I haven't driven the GTI Golf yet, maybe they changed it back to the way you've described.
    Quote Originally Posted by Eaglehawk View Post
    Yes and I never use autohold either. It lets off with a jerk so never bother, but then there are no hills where I live
    I would think apart from the Coast function they are basically identical and the way you should treat them would be the same
    Jan 2009
    FYI, 'BlueMotion' is an umbrella term used by Volkswagen to promote their fuel-saving technologies. These include, but not limited to:
    - Start/stop system
    - Regenerative braking
    - Lower idle speeds
    - Taller gear ratios
    - Gear shift indicator
    - Engine technology (turbocharging, direct-injection, cylinder deactivation, optimised engine management software)
    - Aerodynamic design
    - Lowered suspension
    - Low resistance tyres
    - Weight reduction
    Not everything on that list applies to all models, irrespective of whether or not the BlueMotion moniker is plastered all over the car.
    In regards to the Start/stop system itself, you should read the owners manual carefully if you haven't already done so - this tends to answer 90% of queries asked by owners on this forum.
    If you are still having difficulties, then you should explain to the salesperson what the issue is (even if you can't demonstrate the problem), who may clarify your understanding of how the system works.
    If the problem persists, then there may be a technical fault - in which case, you'd need to book it into the dealer's workshop.
    Quote Originally Posted by Brendan_A View Post
    The mk7 GTI with bluemotion we drove would restart with slightest release of the foot brake. Didn't try it with auto hold on, so can't comment on that.
    My mk6 golf doesn't have bluemotion.
    The Passat requires you to hit the accelerator IF ITS IN AUTOHOLD ONLY.
    Otherwise just lift off the brake a bit and engine will restart and just roll away when brake is fully released.
    It seems Brendons post confirms this in a MK 7
    Nov 2009
    SEQLD
    Yes, went back and drove the MK7 GTI aging this morning. With auto hold on you just had to press the accelerator and engine would start up.
    Also found out when engine is cold or car hasn't been driven in a few days it took 20+ mins for start/stop to work.
    Can't wait to get my new GTI
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Jul 2013
    brisbane
    did they run through the car with you when you picked it up from the dealership to explain what everything does ?
    to me it sounds like the stop/start function is working as it should , if you don't like it turn it off via the button near the gear selector each time you start the car ( this is what we do with ours )
    May 2012
    sounds scary, good luck with it, hope you get it fixed asap!
    safety first!
    MY14 Golf MK7 103 TSI Highline | DSG 7 spd | Pacific Blue | Bi-Xennon | Sunroof | Driver Assist 2 | Leather |
    MY12 Passat B7 118 TSI | DSG 7 spd | Silver |
