Originally Posted by
Yani
Hello guys,
Today I went to a service where they used VCDS to analyze my car. As fault the below showed up.
I was real scarred about the one with 1048574 km since I know that i bought my Golf 7 when it was around 145k km.
Please advise me what should I do regarding this codes. They are serious ? Which of them should be considered as primary.
Thanks
Yani: First, don't worry about 1048574kms - this is the binary equivalent of 11111111111111111110 (i.e. a very large number), which simply means that the control module for the anti-theft system has failed to register the correct time/date/travel-distance when the fault occurred (sometimes happens).
Second, the fault pictures tell you which are the more important faults - look at the "Fault priority" number: the lower the number, the more important the fault (according to VW).
The other aspects of the faults to look-at is the "Fault frequency" and the date. On your first picture the frequency is "9" and the date is "2017. 10. 07". This means that the fault first occurred on 10th October 2017 and the fault re-occurred on 9 x subsequent ignition cycles since then.
IMO, both the engine faults need to be monitored, but since the last fault is intermittent, it may be prudent to just watch this fault. Is the car operating correctly?
