My experience is several years old now, but it might still be relevant. I bought the "extended VW warranty" for my van, and needed it when my gearbox failed just before the warranty ran out. It was only then that I found out that Allianz made all the decisions about what could and could not be done under this warranty. After some delays Allianz decided that my gearbox should be repaired, not replaced. So my gearbox was removed and sent to "the experts" in Melbourne. It took a long time to be "fixed" and when I got my van back it was dangerous (sometimes you couldn't select any gears and it had a terrible shudder). There was a further long delay with much discussion between my dealer and Allianz about what to do next, and it wasn't until I started mentioning lawyers and compensation that Allianz finally agreed to a new replacement 'box. All in all I was without my van for 3 months !
So unless things have changed, the extended warranty sold to you as a VW warranty "the same as" the original factory-backed warranty you get for the first 3 years is most definitely not (the same). I suggest reading the fine print (terms & conditions etc) on any extended warranty VERY carefully before buying it. I know I will go over them with a fine tooth comb.
