This is a helpful article.
1.4 tsi 150 hp engine problems Are TSI engines reliable? Major problems and weaknesses. Engine troit and vibrates cold
At work buy/sell "salvage" vehicles. Over the years we have purchased numerous MK7 Golf's (mainly the twin charger 1.4 and 1.6) which have either suffered a cracked head or are using excessive oil due to skinny / weak piston rings. Some Audi's (A3 I think) have the same issue. It's just poor design.
You could source a used engine, the CSXA has a revised head which would be a better option. But still suffers from the thin piston rings anyways so even a used engine could have similar problems. Stretched timing chains is another problem.
You could go for a rebuild assuming the head isn't cracked.
As for the ECU, that's a tough one. It may be possible for the current ECU to be remapped to the CSXA. Or it may not even be necessary, really depends on what intricate changes VW have made (changes to sensors, diff sensor plugs, relocation of pipes/hoses) between the CMBA and the CXSA.
Personally, I don't think it is worth the excerise, I'd just get rid of the car.
