Results 1 to 10 of 11
Thread: Enable Disable Cornering Light
    Sep 2017
    Portugal
    Hi,
    It's possible to disable cornering light on car menu?
    Or it's just possible on VAGCOM? Is there any way to show an option on screen to enable or disable cornering light?
    Thanks.
    Best Regards,
    Chirag Geiantilal
    '06 - Volkswagen Passat 3C 2.0 TDI Highline - 2009 - 2017
    '12 - Volkswagen Golf VII 1.6 TDI Confortline - 2015 - ...
    Pacific Paradise QLD
    Why would you want to do such a thing.
    Sep 2017
    Portugal
    It's just a question, it doesn't mean that I want to. Just wanted to know if there's option.
    Best Regards,
    Chirag Geiantilal
    May 2013
    Do you mean the low power light from the side of the car? Or the Dynamic Cornering lights (Xenon bulbs)?
    If it’s the former, check in the Car settings.
    If it’s the latter, then use the DCC system to switch to Eco Mode for the Dynamic Cornering Lights (under the Individual settings).
    (I only found this out after a year of running them in Eco and then suddenly realising I’d never seen the lights move!).
    Sent from my iPhone using Tapatalk Pro
    MY08 Mk5 GT Sport - sold
    Sep 2017
    Portugal
    Quote Originally Posted by Mattlock View Post
    I'm talking about the fog light as corner light. Also when I put reverse gear it light up fog light. It's possible to disable via infotainment?
    Best Regards,
    Chirag Geiantilal
    May 2013
    Yeah, so there may be a setting for that in the Car menu (under lights). I can’t remember 100% but I think I saw something there.
    If not, it’s a VAGCOM thing to sort out.
    Sep 2017
    Portugal
    Can you check? I also remember to see... But now I can't see...
    Best Regards,
    Chirag Geiantilal
    May 2013
    So in the Car menu, it also has the controls for Dynamic Cornering Lighting but it seems to be different to the controls in the DCC menus (even though they are labelled the same). So either they do different things or in my car (a 7R) the DCC overrides the Car menu.
    As it was morning, I couldn’t tell. I will play with it tonight.
    Sent from my iPad using Tapatalk Pro
    Sep 2017
    Portugal
    Well I don't have xenon. Only fog light as cornering.
    I think I saw somewhere option to turn off fog light when reverse... now I can't find it.
    Best Regards,
    Chirag Geiantilal
    May 2013
    OK, so I checked in my system and the settings I have are directly related to the Dynamic swivelling Xenon headlights and I can’t deactivate the fog light illumination feature.
    So it sounds like it’s a VAGCOM thing.
