Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 146
Thread: Electronic Parking Brake in Golf 7
  1. #81
    Pacific Paradise QLD
    Doesn't in the Passat either You have to pull it up to set it. Train wife buy diamonds wave in front of her till she does it automatically.
    Then hide diamonds in case she forgets. LOL
  2. #82
    Feb 2013
    Melbourne, Australia
    The handbrake on our Alltrack comes on (and off) automatically.
  3. #83
    Mar 2014
    Perth, WA
    Problem is we have other cars WITH handbrakes. Its more likely I will forget than her as it will be her daily drive and I drive an old 94 Patrol
  4. #84
    Jun 2013
    Act
    The DSG has an auto hold feature, so if you leave auto hold turned on the park brake will automatically engage when ever the car stops. I'd assume a manual has the same feature?
    May 20 - Nov 19 MY20 Tiguan 162 TSI
    May 16 - Apr 16 Mazda 3 Sp25 GT - 2020 hail storm write-off
    May 13 - 2013 Mk7 Golf Highline.
    May 10 - 2009 Falcon G6E with beige leather.
  5. #85
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Nauend View Post
    Yep this is true on our tiggy although only when you turn the car off. But I hate the auto hold function so generally don't have it turned on.
  6. #86
    Jun 2011
    Sydney NSW
    Quote Originally Posted by flashman1207 View Post
    Oops, I forgot to add that its a manual I am considering.......
    Actually, you can be fined and get demerit points for not leaving the transmission in gear when you park a manual. I know my brother did. He just had the parking brake applied. As the brakes cooled down, the pressure came off the brakes and he found the car had rolled down the street and into a power pole. Fortunately no one or car was hit, but the police were called and he was fined and got demerit points for failing to leave the car in gear. You might even fail your driving test because the last thing you are asked to do by the examiner is to park the car and secure it.
    Automatic transmissions have a dog clutch that blocks the output shaft from rotating when in Park.
  7. #87
    Quote Originally Posted by davo View Post
    If you have autohold on. Will only come off automatically if you have seatbelt on also.
    I rarely use autohold therefore mine does not come on when I stop.
  8. #88
    Mar 2014
    Adelaide Hills, South Australia
    The auto hold function uses the abs pump based on the brake pedal pressure when you come to a stop, not the electronic handbrake.
  9. #89
    Erskineville, NSW
    Quote Originally Posted by wai View Post
    It's also sensible to turn the wheels into the kerb on a hill. I believe it's a legal requirement on the Streets of San Francisco - Carl Malden will book you.
    It doesn't take much of a drive or much heat in the brakes to get the rotors expanded enough so they let go when they cool. I've had it happen on my car in my driveway.
  10. #90
    Just been out and tried mine.
    With the Auto hold OFF the handbrake does not apply automatically.
    With Auto hold ON it does.
    It does not release under either unless the driver has their seatbelt fastened
