Originally Posted by
Hillbilly
If you are driving correctly both your hands should be on the steering wheel not playing with buttons on the centre console.
If the switch is on the drivers side of the console as it is in the Passat a passenger would have a hard job to interfere with it.
Hillbilly: The passat sounds like it has a better arrangement. The center console on the mk7 is (in my view) quite well arranged in terms of access. The e-brake swtch are on the passenger side albeit I wouldn't have thought that much would change if it were on the driver side
Flight
I much prefer the e-brake to a traditional lever.
Flight: I've been unclear in my view about the e-brake - my apology. I'm not saying that the e-brake is any worse, or better than the more traditional brake lever - it's just different! After about a year of owning a mk 7, I remain totally agnostic about the value or otherwise of this particular feature
I guess like all technological developments, the e-brake seems to have its advantages and disadvantages. The increased risk of inadvertant operation is just something that drivers need to be aware of (especially if the passenger is a child with a fidgetty personality - or the driver is the same ). On the other hand an advantage of the e-brake is the fact that it is electrically connected to the auto gearbox. This allows the e-brake to be automatically disengaged when the driver puts the car into the drive position (something I learnt from this thread).
The further disadvantage of the e-brake seems to be the added complexity of changing the brake pads. I'v watched a video on the Rosstech site about how to correctly do this task. What is a relatively simple task on a normal car requires a VCDS cable (or similar facilty) on a mk7 to open/close the calipers (because of the e-brake).
PS: The my13 version of the SatNav already has a Seargent Schultz personality. Whenever I try to punch-in a new route address the voice response is invariably "I KNOW NOTHING" !!
