Brian: first, before you spend any more money - get more information about the problem. For example, get hold of a diagnostic device (VCDS, or OBD11, or other) and read the error message that most likely will be present in the BCM relating to the fault. The newer stye modules in the mk7 (yes, they are very differen't to the mk5/mk6) are more informative - so use the data that's available in the car. It may save you lots of wasted time and expense chasing the wrong solution.
PS: don't bother chasing fuses of the exterior lights on a mk7 - they don't have the traditional arrangement of fusing each lamp. Lamp protection on a mk7 is managed directly by the BCM
