Results 1 to 10 of 19
Thread: Dual Mass Flywheel DMF Failure 7 speed DSG 100k milage, MK7 Golf 90TSI 2013.
    Mar 2015
    Newcastle, NSW
    Hi Guys,
    I was after some advise regarding a DFM failure. The car is a 2013 model, 100k, 7 speed DSG. It is just over 5 years old. I have had the clutch packs replaced under warranty at 40k, and again at 90k. At 100k, the 3rd clutch was beginning to shudder on take off and gear changes (just like the first two clutches), when the DMF failed.
    VW Australia have offered a 30% discount on parts, but still want $2500 to replace the DFM. They refuse to do anything about the clutch as they said they inspected the clutch packs and they look fine.
    The dealer has admitted they haven't had any MK7 golf with this problem, and that it shouldn't fail at this many km.
    My argument is that the previous failed clutches have possibly caused excessive vibrations and reduced the life of the DFM. Also, that the DFM is expected to last longer than 100k regardless of what caused it. Under Australia Consumer Law, the products should last the expected lifespan, and the manufacture should provide a remedy for failures.
    What are your guys and gals thoughts on this?
    Cheers.
    Pacific Paradise QLD
    Quote Originally Posted by VWTDI View Post
    Hi Guys,
    Cheers.
    How many times have you launch started it
    Feb 2008
    NSW
    On a typical manual transmission (and presumably the same on a DSG) the friction surface of the flywheel is a "consumable" like the clutch itself and will eventually need to be replaced. The conventional wisdom used to be that if the clutch needed replacing you would have a low threshold for replacing the flywheel at the same time, the theory being that a brand new clutch and a part worn flywheel would not operate well together and possibly accelerate the wear of both, not to mention the obvious benefits in terms of labour costs. So in short I not surprised the flywheel needs replacing and you are probably right that the issue has been caused by marrying up brand new clutch plates with a part worn flywheel and that the flywheel probably should have been done long ago. The tricky bit will be convincing an outfit like VW this far down the track.
    Sounds like you need a second opinion - why not call in to see Pete at Newcastle VW Centre at Wickham and see what he suggests.
    If that location is not suitable, try Twilight Automotive at Cardiff (Munibung Road).
    And if its of any assistance, Newcastle VW Centre did some work on my old Mk6 Golf GTI when it had about 80,000km on it (they replaced a leaking rear main seal which requires removal of the gearbox) and he said my DMF had some wear on it but still had life left in it. My car was a manual transmission but the lifespan of the flywheel should be similar to your car.
    Mar 2015
    Newcastle, NSW
    Cheers guys. The DFM on this car is actually separate to the clutch plates. They don’t actually contact. I can’t argue about contamination or heat from worn clutch packs as they are housed separately. The dampening springs in the DFM gave way and I’m arguing that is an unreasonable failure on a car with 100k and 5 years old, and potentially caused by the three failed clutches. The car is nearly always driven like a granny as it’s my partners. The VW dealer said they would go back to VW and try again for a remedy so I’ll see how I go and talk to Pete if It doesn’t get resolved. Cheers for the help I’ll keep you guys updated.
    Dec 2015
    Launceston, Tasmania
    "The car is nearly always driven like a granny as it’s my partners."
    It sounds to me like the car is being driven as though it's a full automatic, rather than a DSG. It simply should not be going through clutches like this.
    Excessive clutch wear like this in a DSG is a symptom of the car being held at lights/intersections on a slope by holding slight pressure on the accelerator - or "riding the clutch" in the old money. The driver needs to learn how to use just the brake when the car is meant to be stationary.
    Mar 2015
    Newcastle, NSW
    Quote Originally Posted by trojon View Post
    Nope the car is being driven as it should. It's driven very easy by my partner. I've shown her what not to do in a DSG. VW said the previous clutches were faulty (not excessively worn) and upgraded to the new design, twice.
    Mar 2015
    Newcastle, NSW
    I just heard back from the VW dealer. After going back to the VW head office 3 times at my request and explaining to them what my rights are under the Australian Consumer Law, they have agreed to replace the flywheel at no cost to me. Well done VW!
    Apr 2011
    Looks like all that ACCC action is now starting to actually have an effect. Congrats!
