The DSG in the TDI’s, GTI’s and R’s are solid and generally very reliable. This covers the 6 speed DQ250 (used in Mk5, Mk6 and early Mk7’s) and the 7 speed DQ381 found in the facelift Mk7.5 models. Obviously with any mass produced product you will get the occasional dud or problematic one.
The DSG’s used in the lower spec/lower powered Golf’s (DQ200) is the problem child you have probably read about - its a different DSG gearbox to that what is fitted to the TDI/GTI/R and are well known for their flaws and issues.
Manuals are pretty hard to find unfortunately, as the vast majority were sold with the DSG gearbox. Having owned both manual Mk6 GTI and R, and now a DSG Mk7 GTI I do prefer the simplicity, reliability, and smoothness of the manual. Note that the manuals have a weak clutch, so if you plan to get your new car tuned for more power and torque, you will more than likely exceed the holding capacity of the clutch - resulting in a slipping clutch. Obviously a new clutch with a higher torque rating can solve that issue but will cost you about $1500.
