During my test drive of a 103TSI wagon the other day, I observed that the car would roll a lot further/more easily than my current 118TSI wagon so they have definitely improved some stuff here. I usually average around 6.5-6.8L/100km in the Mark 6 wagon (that's with a clutch pack that still shudders/slips) so I'm realistically expecting around 5.3-5.4 with the new one given the way I drive. I hope!!
Hi All,
Apologies if this has already been answered somewhere.
Does MY16 Golf have the coasting feature?
Thanks
You've got to have the Driver Assistance Package so you get the vehicle profile selection.
From there, if you put the car into ECO mode you will get proper coasting.
ooh
You are not missing out on much anyway unless you live in the middle of nowhere with straight roads, no traffic and loads of traffic lights.
The system decouples clutch when you back off throttle, essentially putting the car in neutral, only engaging the clutch again when you:
1. Go back on throttle (with major delays due to gear selection etc) or
2. Brake (and it doesn't disengage again even if you only touch the brakes unless you touch the go peddle again)
The system is great in principal, however let's look at real world usage:
Generally, in city traffic, you back off throttle because the car in front has started to slow down, you are going downhill or you are rolling to a set of lights. In this state, the car is not burning any fuel, and this usually provides enough resistance for you to hold speed (downhill), or roll to a stop with reasonable pace.
However, with ECO mode, the following situations occur:
1. Going downhill - Clutching out is useless as you pick up speed like a run away car, so you have to use the brake anyway to shave off the extra speed you have just picked up. Clutch engages.
2. Car infant of you slowing down - Clutching out means you roll a bit further, but it also mean you will catch up to the car in front really quickly, so you need to apply brake. Clutch engages.
3. Rolling to a set of lights - Again, unless you live in the condition first described, or it's the middle of the night in city areas, there are hardly any chances where you could back off throttle 3-500m before a set of lights and just roll to a stop without pissing the **** out of the guy behind you.
4. And this is a big one - When you de-clutch, you are still burning fuel to keep the engine idle. So while in normal mode, you burn 0 fuel rolling to a stop, in ECO, you actually burn fuel while your car is coasting. This is fine if you have the luxury of rolling for a long time so your fuel usage is offset by your rolling distance. However, in city conditions, you generally roll for a small distance, only to have to brake (usually harder to compensate for your faster rolling speed in ECO) to stop, in this case, you are not really saving any fuel.
While I don't have conclusive evidence to back up my claims, my limited testing has shown ECO mode to use more fuel during peak hour traffic compared to just using Normal. Both done with AC off, windows up, but are subject to the traffic conditions at the time. Having said that, fuel figures for both modes came back at about 6 l/100k or 6.2 l/100k, so the difference is not great by any means.
Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
Exactly!
Where it would save you fuel is the lower up shift point and altered aircon profile the car gets real warm tho before it would kick back in at the lights...
The coasting function facilitates conservation of momentum - unlike normal torque-converter automatics which engine brake every time you lift the throttle. When you DO want engine braking with a VW DSG, you just tap the brakes. So coasting function gives you the option - engine braking or not - where is the downside? I appreciate it very much.
MY13 Passat 130TDI
MY12 Amarok 120TDI
ZF disagrees with you
ZF begins production of second-generation eight-speed automatic transmission
The transmission’s ‘coasting’ function – the uncoupling of the gearbox and simultaneous stopping of the engine – now operates at speeds up to 160km/h. ZF has also further optimised the stop/start function, with the engine now stopping immediately as the vehicle stops, rather than waiting 1.5 seconds as in the original eight-speed.
