Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 110
Thread: Driver Assist Package II - Discussion and Questions
  1. #41
    May 2011
    Melbourne, Vic
    Is this something I can retrofit to a car with the first gen DAP? Do I need to replace all sorts of parts for this to happen?
  2. #42
    Aug 2007
    You need at least the following.
    Glass that supports blind spot mirror
    Master and Slave radar modules
    Associated Wiring
    Potentially need new mirrors however you could probably make up the wires and run your own through to either the door controller or bcm, i havenn't checked on wiring.
    There is another post around on vwgolf.net.au for mirrors where i details the part numbers. you would be looking at least $2000 to retrofit.
    Quote Originally Posted by zardoz View Post
  3. #43
    Mar 2015
    Warner, QLD
    And you need VW to do the calibration for you apparently.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  4. #44
    May 2015
    Perth, WA
    Quote Originally Posted by agentthumb View Post
    Hey all, was looking at the VW website. In the build and configure tool for the Golf, Driver Assistance Package II is listed. However, there are no details anywhere about it on the site, or their sales brochure.
    I've read somewhere it's the same as Driver Assist Package 1, but now with blind spot monitoring and rear cross traffic alert. Can anyone confirm this please?
    Hi. I have also recently noticed that the VW AU website is now suggesting that the new Golf (MKVII) is available with DAP II. You are very correct in that VW AU is pretty quiet about what exactly DAP II includes. I ordered a new Golf TSI103 with R-Line package and DAP in Feb and questioned the dealer just the other day about exactly what my vehicle would arrive with given I had noticed that DAP II was now being advertised on the AU website.
    It would appear that new orders for MY15 Golf's from late Feb - early Mar 2015 will be delivered with DAP II (where ordered as an option). The dealer indicated that my vehicle would be DAP II equipped. It was suggested that this would mean the addition of Blind Spot Detection over and above the std DAP package.
    As a newbie - I hope this helps!
  5. #45
    Sep 2008
    I presume the functions are as listed in the MY15 brochure specifications.
    Driver assistance package - optional:
    Adaptive Cruise Control (ACC)
    Front Assist with City Emergency Brake (City EB) function
    Driving profile selection
    Park Assist, parking bay and parallel parking assistance
    Proactive occupant protection system
    A lot is listed as standard (except the poverty pack model which only has the first 2 and dealer accessory rear parking sensors):
    Driver assistance systems (standard):
    Driver Fatigue Detection system
    ECO tip function, fuel efficiency advice
    Parking distance sensors, front and rear with acoustic warning and audio volume level reduction when sensor warning is activated
    Optical Parking System (OPS) in radio/navigation display
    Automatic kerb function when reversing, passenger’s side exterior mirror
    Rear View Camera (RVC) with static guidance lines
    I presume with the optional package, the front parking sensors are deleted in favour of the front radar that runs the adaptive cruise and city emergency brake.
    No idea what the "Proactive occupant protection system" is.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
  6. #46
    Mar 2015
    Warner, QLD
    Blind spot is still not listed.
    Front parking sensors are not deleted. Radar and asking sensors are both present.
    Proactive occupant safety is closing windows to a crack and tightening seat belts when the car thinks you are being reckless.
  7. #47
    Dec 2013
    Hi All,
    Have a GTI Performance with driver assistance package 2, picked up in late April. Everything has been working well until last week.
    I dropped the car in to get a bushing/bearing in the front left wheel replaced, as it had been slightly noisy at hard lock since new. Part replaced no problem, noise gone. As I drove out of the dealer it flashed up on the MFD telling me that “Rear Traffic Alert / Blind Spot Monitor currently not avail.”
    At the time I did not think much of it because the car was really dirty and I though it might just be a dirty sensor. Cleaned the car, no luck. Just took the car back to the dealer and they spent 20 minutes fiddling around trying to figure out what was going on but with no luck. They are telling me that I need to drop it in for a whole day so that they can take an extended look and try to figure out what is going on.
    Has anyone seen this error before? Any ideas?
    Attached Thumbnails Attached Thumbnails Driver Assist Package II - Discussion and Questions-2015-06-22-07-14-41-jpg   Driver Assist Package II - Discussion and Questions-2015-06-22-07-14-52-jpg
    Driver Assist Package II - Discussion and Questions-2015-06-22-13-23-37-jpg
  8. #48
    Nov 2009
    Quote Originally Posted by timmehs View Post
    Get someone to scan the car with VCDS to get an idea of what the issue is. It should have logged a fault code. Surprised the dealer didn't check this actually.
  9. #49
    Dec 2013
    Thanks Adam. Don't know of anyone with the Ross Tech cable. Have the car booked back in with the dealer for next Wednesday so will find out then. Disconnecting the battery for ten minutes to try and hard reset everything didn't work.
  10. #50
    Nov 2009
    If you're in a hurry: http://www.vwwatercooled.com.au/foru...elp-27504.html
