Results 1 to 10 of 14
Thread: Dreaded DSG Gear Change noise.
    Sep 2018
    Started noticing the dreaded DSG Gear change noise yesterday. grinding sound.
    Warranty ended on 7th October 2018. 26k km's on car. I can kick myself for buying a VW.
    Spoke to VW today and they said VW may still cover some of the costs to repair, however I never did the 25k service at dealer so chances are slim.
    so, any ideas what I am up for if I need to get it repaired out of warranty? Obviously try and avoid using the dealer.
    Sep 2009
    south australia
    Quote Originally Posted by 65F100 View Post
    What model , motor etc
    GTI clubsport/edition 40 manual white 2016
    Mercedes Benz A200 AMG pack red 2016
    Pacific Paradise QLD
    What 25k Services are at 15k intervals
    I assume he is going off time rather than km's seeing the car has low kms for a 3yr old car.
    Feb 2008
    NSW
    It does not matter where it was serviced if it was done on time and you have receipts then you have complied with the warranty terms and conditions.
    You are only about 2 months out of warranty on a car that has done not far off half the typical mileage for a 3 year old car. I would be pushing hard for some sort of good will from VW particularly if this is a big ticket repair bill.
    Sep 2018
    Model is a 2015 TSi.
    Going to dealer next week. Fingers crossed VW will come to party, but preparing for the worst. Bought the car 4 months ago.
    Mar 2014
    Queensland
    In my opinion VWA should cover the whole repair under good will as the car is just out of warranty and with such low Kms, especially if it is the 7 speed dry clutch. They were a problem at one stage although I can’t remember what the characteristic problem was.
    You need to be very strong with them and not take no for an answer!
    Sep 2018
    Quote Originally Posted by Benz View Post
    Yes, from what I have researched it is common to the issues that was around at one stage. I think there was an update in mid 2015 and my vehicle build date was Feb 2015. Just what I have read on interwebs.
    Not sure if I will have much ground to stand on if they refuse to repair it, but I won't give up without a fight.
    Nov 2015
    Adelaide, South Australia
    This post in the MK6 forum might make you feel better...5 yr old mechatronics, fully covered.
    MK6 Golf Mechatronics Failure - Warranty?
    Mar 2014
    Queensland
    Great find Valvster that should help although hopefully if you talk to VWA directly, if the dealer won't help, they will willingly fix it at no cost. You can also argue "not fit for purpose" under consumer laws etc if they don't.
    Good luck and please keep us informed of the outcome.
    Quote Originally Posted by Valvster View Post
