Originally Posted by
bradsm87
I have no need for lots of ground clearance but I do want a bit more zip than the 1.4L models offer and AWD. An R is out of the price range.
I know the Subaru Outback has a spaced down rear subframe and different front suspension pickup points vs the Liberty. Does the normal Golf and Alltrack also have changes to geometry or is it just a matter of swapping in some good aftermarket spring/shock sets to suit normal Golf height then it's effectively exactly the same as the low models?
Thanks in advance!
This seems to be a common mod on the vw vortex site in the US you could check there but with the amount of lowered ones i have seen i don't think you will have much of a issue as the alltrack is only jacked up by a small amount
I thought about doing mine but i like the extra clearance on gutters and steep driveways i hate hearing the grunching sound of your front lip grinding away
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
