Results 1 to 6 of 6
Thread: Does the Alltrack have changed suspension pickup points or spaced down subframe?
    Jul 2013
    Tas
    I have no need for lots of ground clearance but I do want a bit more zip than the 1.4L models offer and AWD. An R is out of the price range.
    I know the Subaru Outback has a spaced down rear subframe and different front suspension pickup points vs the Liberty. Does the normal Golf and Alltrack also have changes to geometry or is it just a matter of swapping in some good aftermarket spring/shock sets to suit normal Golf height then it's effectively exactly the same as the low models?
    Thanks in advance!
    Apr 2017
    belgrave victoria
    Quote Originally Posted by bradsm87 View Post
    Thanks in advance!
    This seems to be a common mod on the vw vortex site in the US you could check there but with the amount of lowered ones i have seen i don't think you will have much of a issue as the alltrack is only jacked up by a small amount
    I thought about doing mine but i like the extra clearance on gutters and steep driveways i hate hearing the grunching sound of your front lip grinding away
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Mar 2014
    Newcastle, NSW
    I wonder if it means I could lift my R Does the Alltrack have changed suspension pickup points or spaced down subframe?. I hate the scrape Does the Alltrack have changed suspension pickup points or spaced down subframe?
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
    Jul 2013
    Tas
    Quote Originally Posted by hardy_bm View Post
    I'll buy an Alltrack then let's just swap cars!
    Jul 2013
    Tas
    Quote Originally Posted by Kachingg View Post
    I know it's easy to lower and not an issue as such but I want to be sure I'm getting the same suspension geometry as say a Golf R.
    Erskineville, NSW
    Thanks in advance!
    Skoda does their Superb Outdoor and Octavia Scout lift using a combination of larger diameter tyres (+10mm) and raised springs (+10mm). I'd be thinking VW use a similar method.
