I didn't really like the S3. I went and had a look at them (i was coming out of a 2004 4.2L V8 Audi S4) and i felt that i would rather the top of the VW performance tree rather than the bottom of the Audi performance tree. Also all of the reviews seem to say the Audi is good, but not as good a drive as the Golf R.
Is the RVC better resolution? It's crappy on my Gti and I wonder whether the screen is holding the camera back or vice versa
I guess the question to ask is whether cars with discover pro overseas get a better RVC or if it's the same unit regardless
My wifes passat with the RNS510 seems much lower resolution. The Discover Pro 8" is still only 800x480, but with its larger size it seems very clear whats going on behind you. I think the screen on the Discover 5.8" is the limiting factor, not the camera.
I have no clue how car manufacturers think less than 1920x1080 is appropriate for a screen of this size, considering you can buy a tablet with that res for about $150
Hey dtpearson well done on the upgrade, a bit out of my price range but good to see it has been done, now bloody hell Volkswagen give us the option of buying it you dipsticks.
Can I ask how much the VW plug & play Helix subwoofer prices are, where did you order and who will be doing the install.
Also any information you have would be great, did you find out what the price would be from a dealer, every dealer i talk to has no idea what i am talking about, any information would be a great help.
2019 MY19 Mini JCW Hatch
2016 Holden Astra RSV - Waiting for New Golf
Hi, since changing my infotainment unit to a european spec one (as my car is a japanese import) and having the component protection removed i have no nav, it just says no nav data, just ran a check and have 2 fault codes
Monday,02,February,2015,14:31:12:17628
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
Dealer/Shop Name: TDMCK
VIN: WVWZZZAUZEW243462 License Plate: GOLF 2014
Address 5F: Information Electr. Labels: None
Control Module Part Number: 5G0 035 020 D HW: 5G0 035 020 D
Component and/or Version: MU-H-ND-EU H43 0362
Software Coding: 02730001FF00000011111201000800001F0203C60100010076
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_MUHig4CHBAS 001040 (VW37)
VCID: 1A3193311DDB65F181F-804F
2 Faults Found:
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 3705 km
Date: 2015.02.02
Time: 14:24:32
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 3705 km
Date: 2015.02.02
Time: 14:24:34
i know why the antenna fault is there but its the nav one i am trying to sort !! the nav was working before component protection was removed ... it says nav database not enabled ? is this something i can enable with vcds or is it VW only ??
thanks glenn
Be careful with the Plug & Play Helix system, i havent got it installed yet, and i may have bought the wrong one. There is two identical looking and identically named models with sightly different model codes. I was working from translated german websites, i got mine from Amazon UK as they are RHD and should be similar spec to Aus cars, but it looks like there is a universal fitment one, Code: 000051419 and maybe a MK7 specific one 5G0051419. They are both called the same thing and i bought the unit because a german website lists the "VW Plug & Play Helix system" as compatible with the MK7 Golf R. But i don't really know which one i have (its not even written on the box or instructions).
I will update everyone when i work it all out. But at this stage i may have blown $800, who knows....
I would give Martin a call at Euro Car Upgrades (Home page Euro Car Upgrades) as they seem to be the experts at retrofitting the Discover Pro units.
Ok i think i have a handle on the different part numbers for the Helix VW Plug & Play stereo upgrade kit (with sub), if you order the 000051419 unit you get a universal fit kit that can be fitted to a range of VW vehicles BUT you need a programming dongle to fine tune the system for the car its going into. If you order the 5G0051419 unit, it is pre-coded for the Golf MK7 5 door.
This website seems to show that the 000051419 unit as suitable for the MK7 Golf R
https://alexandriavwparts.com/audipa...atalogid%3D200
