Originally Posted by
Nudist
I only use the golf for interstate travel so you can see were where I’m coming from. If you’re saying that the pandemics over when can I travel to Victoria from the ACT?
Nudist (are you really?): Hi. I won't get into a debate about when the pandemic will be over (it's far too controversial a topic for my feeble brain to contemplate) - but I agree with Lucus that the most appropriate way forward from a battery health perspective if you expect not to use the car often is to use a "smart charger".
If your view is that the pandemic will be protracted, you might even consider making a loom extension for the charger.
I've done this on a few cars now. It's a simple (fused) 2 x wire loom that bolts onto the +ve battery terminal and the car frame (important not to connect to the -ve battery terminal for cars with Stop Start) at one end. And, it has a good quality (Gold) 2 x pin connector at the other end which mates into a matching connector on the charger leads. The extension makes it very easy to both hook-up and remove the charger.
I've suggested to the owners that they leave the bonnet lifted while the car is connected to the charger as a memory prompt - so that they don't forget before putting the car into gear. But on a couple of cars, the owners have wanted not to have to open the bonnet when connecting/disconnecting the charger - so the plug-end is outside the car and I've included a "blind" connector on the loom extension to stop detritus/water from entering the connector while the car is in motion.
