^^^^hmm...... OK - ain't nothing particularly special about the connectors -they are widely available and I've been using them for many years now on all sorts of battery applications both in cars, on radio controlled devices and anywhere where VD (volt drop - not the disease) and potentially high electrical current draw might be a concern. And of course, the connectors are corrosion resistant - so especially suitable for charger extension looms where the car owner doesn't want to have to lift the bonnet to make the charger connection.
As I said, lots of variants available on the net, but I'm tending towards Dean plugs of late (sometimes called "Tee - plugs") - Google the term!!
Nudist: Most (all?) of the important "settings" in the car will be stored in non-volatile memory - so disconnecting/connecting the battery shouldn't be a problem.
However, when you reconnect the battery, you will generate a number of alarms in the car as the modules attempt to re-establish their initialization parameters. Most of the alarms will self clear shortly after the rail voltage in the car stabilizes (try cycling the ignition switch a couple of times - it often helps). Any residual alarms that may persist should be cleared by taking the car for a short drive. It will take longer for the car to validate its internal emission tests (called "readiness" in the engine module) - however these tests normally sit in the background without the driver being aware that they are occurring.
Until the pandemic I left my 2011 GTD in a garage for up to six months a year whilst working overseas. I lowered the tyre pressure and put it on a trickle charger from Bunnings. Nil problems. My first battery lasted 7 years. And leave fuel below quarter so can top up with fresh when ready to go again...
Good advice. Going for a short drive is supposed to fix the multitude of error messages you get after disconnecting the battery.
I don't know how effective these tyre savers are, but they are supposed to reduce flat-spotting:
Tyre Saver (Pair)
Hi Nudist,
I have the same problem not driving much at the moment so I hook up a small 12v solar panel from supper cheep auto that has the wire permanently connected to the battery terminals.
It just sits on the dash board. I didn't want to fix it to the dash so all I have to do is move it into the doors side pocket when I drive.
Its only a 300 ma 4 W peek current unit, and it only charges when there is sun so its not going to over charge the battery as it will naturally lose some charge and the car uses some power even when its not being driven.
1993 Golf GTI MarkII|5door|Manual|Black|Auto sunroof|Sports Exhaust|Tint|
2010 Golf VI STI|7SP DSG|Reflex silver|5 Door|Park Assist/Auto Park|ACC| 2014 Golf VII GTI Performance|6SP DSG|Night Blue Metallic|Driver Assistance pack|Vienna Leather|Tint. 2015 Golf R 6SP DSG, Sunroof, driver Assist, REVO stage1 programing. 2017 Golf R 7.5 MY18, DSG Driver Assist.
