I can confirme the voltage method works with 12.12 vcds and golf mk7 2014 1.4 TDI.
2 DV52 Thanks. My apologies. You are right.
Hello, i have one question. It is possible to set as a default value (when car starts for the first time) the start stop function as disabled (the button light is turn on). I would like to go on this method since are times when i want to use the function so I would not permanently disable the function. Thanks![]()
forget itas long as i understand the only method is the DV52 method (nice job by the way) or with a special module. I thought that this would be possible with VCDS
Hi all - I have disabled stop/start via the app on obdeleven. Was just wondering if it would be possible to have the stop/start active in eco mode only?
| 2016 VW Golf R 7 | DSG | Pure White | Leather | Sunroof | Driver Assist | JB4 |
| 2003 VW Golf SE | Auto | Silver | Sunroof |
| 2010 VW Golf R 6 | Manual | Leather | ACC | 19s | Black Pack | GIAC Stage 2+ |
^^^^^^^^ hmm.......... I'm fairly certain (almost certain) that it's not possible with the VCDS/OBD11/VCP tweaks (both "voltage" and "temperature" methods) to distinguish between "eco" and normal modes.
Remember that these tweaks are "hacks" really that fool the car into believing that SS shouldn't be engaged - they have absolutely zero sophistication!
PS: but I'm happy to be proven wrong
Cheers Don, I thought that may be the case - would be a good mod though.
I'm amazed that people still try to defeat SSS by tweaking software, paying for OBD dongles etc.
I installed a custom made "DV52 Device" over two years ago and it has performed without fault and is instantly re-energised by hitting the button.
The DV52 device simply reverses the logic of the SSS so that it is set to "OFF" on start and can be set back on when required.
Without doubt the best solution so far.
